Go to Post It's always better to figure out why a design actually works and the best ways to implement it than to just assume upgrading to a "better" material will make everything work. - Cory [more]
VEXpro
ADVERTISEMENT
Unread 12-10-2009, 04:16 PM
nighterfighter nighterfighter is offline
Crazy Programmer Guy
AKA: Matt B
FRC #4509 (Mechanical Bulls)
nighterfighter has much to be proud ofnighterfighter has much to be proud ofnighterfighter has much to be proud ofnighterfighter has much to be proud ofnighterfighter has much to be proud ofnighterfighter has much to be proud ofnighterfighter has much to be proud ofnighterfighter has much to be proud ofnighterfighter has much to be proud of
Drilling through a magnet?
About 2 weeks ago, our team was bored, and while sitting around, we found a really old radio. We proceeded to void the warranty (giggle giggle) and fiddle with it.
We took out some of the things (and it still worked, weird) but when we ran out of things to take out, we went for the speaker.
We got the magnet and its housing out, and then I attempted to drill through it.
Eventually I got the magnet out of the casing, so now I have JUST the magnet itself...
We want to drill a hole through the middle of it, but it is causing us trouble.
Long story short, we now have 2 melted drill bits and a hole-free magnet.
When I use our drill press on the magnet, the bit just spins itself around, but doesn't actually drill through it. The drill press is set to be around 700 RPM, but to no avail.
I thought that if I can just make a small hole to start with it will be easier, but even when pushing it through the bandsaw, it BARLEY scratches the surface of the magnet...
Any ideas?
EDIT: Forgot to mention, the magnet is a cyclinder, about 1 inch in circumfrence, and about 1 inch in length.
Unread 12-10-2009, 04:24 PM
Andrew Schreiber's Avatar
Data Nerd
no team (EWCP)
Send a message via AIM to Andrew Schreiber Send a message via Skype™ to Andrew Schreiber
Re: Drilling through a magnet?
I have many ideas, every last one of them involves finding something more productive to do with your time. Top of my list is that my driveway needs shoveling. My next idea is that instead of trying to destroy said radio you should have figured out how it worked. Destroying something for the sake of education is acceptable (when you have permission) but destroying something for the sake of destroying it is a pointless waste of time.
Maybe the above is just me being a grumpy old man but anytime I see a post about how someone just decided to tear something they found apart I get a little angry. Perhaps I would be a little less irritated if I knew what you hoped to gain by drilling a hole in this magnet? Or what you learned by tearing a radio apart?
$.02
PS. If this post sounds too harsh it was meant that way, to me this appears like kids were just let loose. In addition to destroying the radio they wrecked two drill bits and endangered themselves (the drill bits could have shattered or the magnet could have, neither of which would be good). Where were the mentors? If you have access to a drill press and a band saw someone who knows how to use them should be nearby.
27->397 > 2337 + 314 + 3450 > 79
Unread 12-10-2009, 04:32 PM
Bob Steele's Avatar
The Skunkfather
FRC #1983 (Skunkworks Robotics)
Depending on the strength of the magnet you may not be able to drill through it. Your biggest problem is probably the hardness of the magnet compared with the drill you are using but there are other complications.
The reason this is the case is because the chips that normally would be falling away as you drill are actually attracted to each other and stay in the "hole" They won't leave an empty spot...
So you can't drill.
The holes you see in Neodymium magnets are actually placed there during the manufacture of the magnet.... usually during a compression like activity that forms the magnet.... About the only other way a hole could be made is by an enormously hard and strong punch press....and even then it is extremely difficult...
Weak magnets "might" be able to have a hole drilled in them...but strong magnets will only cause you grief.
It would be like digging a hole in the ground but not being able to take any dirt out of the hole....your shovel would continue to try over and over to remove the same dirt.... it would overheat.... and eventually melt....
Well at least in the case of a drill bit that is what will happen. The heat has to go somewhere and the bit heats...distempers.... turns blue and is wasted...
Also remember that the magnet may well be harder than your blades or bits.... if its not harder it can't cut anyway...
Does that make any sense to you?
Aviation High School TEAM 1983 - Seattle, Washington
LV 07 Rookie AS, WINNER..(w/ 1425/254)...CMP 07 NEW--SEA 08 EI and WINNER (w/ 2046/949)..CMP 08 GAL-- ORE 09 WINNER (w/1318/2635) CMP 09 CUR SEA 10 RCA CMP 10 GAL--SEA CAS 11 - EI, Deans List, WFA Vol of Year--CMP 11 CUR, 6th seed, Deans List Finalist, Creativity award. --OREGON 12 Finalist, SEATTLE 12 Finalist, SPOKANE 12 Deans List, WINNER (w/2122/4082) and RCA-- CMP 12 Newton Semi-- Central Washington 13 WINNER (w/1425/753)--Seattle 13 WINNER (w/948/492) and RCA --Spokane 13 WINNER (w/ 2471/4125)
Unread 12-10-2009, 04:34 PM
rtfgnow's Avatar
rtfgnow rtfgnow is offline
Traveled 1037 miles to volunteer
AKA: Alex Tannahill
FRC #0079 (Team Krunch)
rtfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond repute
Send a message via AIM to rtfgnow
Have you tried punching the magnet?
Andrew, I would be interested to drill through a magnet for the only reason to see if the drill was able to pull about the magnetic bonds within the ions.
I do want to remind people: Safety glasses, adult supervision and don't let freshmen touch the robot.
2011 Smoky Mountain Regional Chairman's Award
2011 Florida Regional Judge's Award
2010 North Carolina Regional Team Spirit Award sponsored by Chrysler
2010 Florida Regional Engineering Inspiration Award
2010 Florida Regional Finalist with 1557 and 801
2009 Tempest N Tampa champion with 1369, 1902 and 801
2009 Minnesota North Star Regional champion with 2970 and 2549
2009 Minnesota North Star Regional Motorola Quality Award
2009 Minnesota North Star Regional Kleiner Perkins Caufield & Byers Entrepreneurship Award
2009 Florida Regional Finalist with 744 and 1251
2009 Florida Regional Motorola Quality Award
2008 Tempest N Tampa Finalist with 801 and 2425
2008 Mission Mayhem Champion with 180 and 1902
2008 Mission Mayhem Judges' Award
2008 Florida Regional Motorola Quality Award
Unread 12-10-2009, 04:36 PM
JackG's Avatar
JackG JackG is offline
Internet is a series of ubertubes?
FRC #0001 (Juggernauts)
JackG is a splendid one to beholdJackG is a splendid one to beholdJackG is a splendid one to beholdJackG is a splendid one to beholdJackG is a splendid one to beholdJackG is a splendid one to beholdJackG is a splendid one to behold
Seriously? Condemning experimentation like this as a waste of time? I wouldn't have expected that from a FIRSTer.
@nighterfighter
I'm hardly the machining expert, but my guess it that you could set the drill press to an appropriate RPM if you had some guess as to what the magnet is made from. For instance, if you found that the magnet is about as hard as steel, you might want to set up the press as if you were drilling steel. As for the drill bits melting, my first instinct would be to try a bigger drill bit. Still, I realize that this may not be possible because of the size of the magnet. My last idea involves using a punch on the magnet to get the bit started. If all that doesn't work, you obviously are holding a magnetic diamond. Congrats.
Edit: Darn, rtfgnow beat me to it
Winners are ordinary people with Extraordinary Determination
Unread 12-10-2009, 04:38 PM
AKA: Matt B
You're right, I didn't really give any reasons.
To begin with, the radio was already in a very poor condition, could only pick up about 3 channels, all of which were covered with static. Anyway, it wasn't like we just tore the thing apart. We actually spent around an hour with it, looking through some of the wiring, and trying to figure out what a particular part was. (After we removed it, the radio still worked, which had us really confused)
One of our other members kept the case to use in a future project (he is going to install one of his mini Mac computers I believe inside of it)
As for the magnet, it may be a "silly" reason, but we want to know what the force in the center of a magnet is.
We know that there is a north and south pole, and if the magnet is broken in half, it forms 2 new poles. But what will the force in the center be?
So yes, we didn't just tear the radio apart for the heck of it.
Unread 12-10-2009, 04:40 PM
rtfgnow's Avatar
AKA: Alex Tannahill
What is with all of the 2 minute posts?
Have fun with your experiment and be safe!
Unread 12-10-2009, 04:41 PM
Bob Steele's Avatar
The Skunkfather
Hmmmmm I think you guys need to take a good physics course if you are looking for the "force" in the middle of the magnet....
Pick up a physics book and take a look at magnetic fields and how they are generated....and the relationships within the magnetic domains in the magnetic elements you are dealing with...
or ask you physics teacher...
even better
have fun!! and I like your curiosity...!!! Keep it up!!
Unread 12-10-2009, 04:49 PM
AKA: Matt B
Bob Steele: I think you are probably right, about the chips becoming attached back to the magnet, and then the blue shavings. (We were wondering what the blue shavings were, haha)
We did try using a bigger drill bit, which did succeed getting through some of it, (I used a 1/2 inch bit) but because that is almost the size of the magnet... heh.
As for the 2 destroyed drill bits: They were NOT new ones, they were several years old, and we have at least 2 more of the same size.
And for the physics course, that's true, but where is the experimentation with that? (Besides, I haven't taken physics yet, sadly. Not open for me until next year. )
Unread 12-10-2009, 05:17 PM
Bob Steele's Avatar
The Skunkfather
I applaud your curiosity/experimentation.... that is how we find out new things...
You should be in my AP Physics class... we actually do some of that experimentation in here...sometimes we even use robots..
Most of the greatest physicists that have ever lived have been great experimenters and observers... You might want to find out more about Michael Faraday.... great physicist... great experimenter....even greater observer...
keep up the good work!!
R
Unread 12-10-2009, 05:23 PM
Data Nerd
no team (EWCP)
Well, then consider my grumpy old person post removed. I was very concerned this was just a bunch of kids without supervision, it doesn't sound like this was the case at all.
I'm not anti experimentation, I've torn my fair share of things apart. Actually trying to figure out how it still worked with parts removed is a pretty cool reason to pull something apart. Did you ever find out? Radios are actually really cool pieces of technology, especially the old ones.
I would say that it is a pretty good reason, physics may be able to tell you what should happen (and what will happen) but sometimes seeing your calculations verified is just wicked cool.
@JackG Not condemning experimentation, condemning pointless destruction. Take for example, Mythbusters, yeah they destroy stuff but they back it up with why it will or won't work. If they just destroyed stuff for no reason it wouldn't be worth much but because they aren't learning anything. If these guys are learning stuff than great for them!
Unread 12-10-2009, 05:41 PM
Flybotix Fanatic
FRC #1885 (iLITE)
Andrew's just mad that he can't figure out a good method to try, so I'll cut him some slack.
A way to do it might be to try cutting a circle with a plasma cutter. Then punch the middle out. The do'ers of this method will probably need gas masks for noxious fumes if it's a rare-earth magnet, as well as alot of other protective gear for the flying molten magnet. There are probably other issues I can't even imagine as well.
Good luck
Healthy people — who know how to deal with disappointment, who have given up on the idea of magic bullets, who don’t watch TV indiscriminately [are] fulfilled by things that don’t cost money
I’m talking about the real fundamentals of being an empowered, self-directed human being. Creativity. Curiosity. Resilience to distraction. Patience with others. And to make these all possible: self-reliance — an unswerving willingness to take responsibility for your life...
How to Make Trillions of Dollars
Want to be a better cook? Do 5 recipes from Plenty on 5 weeknights after work. Eat the leftovers for lunch.
Unread 12-10-2009, 06:03 PM
Rion Atkinson's Avatar
The CAD Guy
I know what I am asking my physics teacher tomorrow. Maybe I can get lucky and she will let us experiment...
I'm with everyone else on this. Be safe, by all means experiment. How else would we learn? Just make sure not to hurt yourselves, it tends to slow down progress for some reason..
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 12-10-2009, 06:21 PM
Beta Version's Avatar
Beta Version Beta Version is offline
AKA: Matthew
FRC #0624 (CRyptonite)
Beta Version is on a distinguished road
It will simply be a donught magnet (which it already was, you just didnt know it). Normally, when we are misinformed that all magnets are bar magnets, we precieve the magnetic field as a 2-D series of lines going from one pole to the other. However, this field also goes linearly through the magnet itself. Realize that for the magnet you have (and all magents) that this a 3-D field that not only goes from one pole to the other outside the magnet, but also THROUGH the magnet. When you remove the center of this magnet, this field will still be going through that void in a similar manner. If you manage to hollow it out, try pushing another magnet through the empty space to illustrate what happens.
And, the drill bit is your problem, its not hard enough. Do you have a set of cobalt bits? Though I would recommend you not ruin them by trying, they would be your best bet. Most of these magnets have been pressure-fired and a very very hard.
Victor 3 Strikes again!
Underwater Bot
Paratrooper Bot
Unread 12-10-2009, 06:57 PM
Greg McKaskle Greg McKaskle is offline
no team (Team NI)
Greg McKaskle has a reputation beyond reputeGreg McKaskle has a reputation beyond reputeGreg McKaskle has a reputation beyond reputeGreg McKaskle has a reputation beyond reputeGreg McKaskle has a reputation beyond reputeGreg McKaskle has a reputation beyond reputeGreg McKaskle has a reputation beyond reputeGreg McKaskle has a reputation beyond reputeGreg McKaskle has a reputation beyond reputeGreg McKaskle has a reputation beyond reputeGreg McKaskle has a reputation beyond repute
Just a thought, but some magnets are formed as a ceramic. Just as metal drill bits don't do a good job drilling through concrete, they don't like ceramic either. If you have chips of the magnet and they seem brittle and "rock-like", you may consider googling to see how to drill ceramic tiles. Of course if you are buying stuff to cut holes in a magnet, perhaps you should just buy one with a hole in it.
http://www.radioshack.com/product/in...ickid=prod_cs#
seems to be what you are trying to make, and it doesn't cost as much as a drill bit.
Greg McKaskle
m magnet? holty531 Pneumatics 2 02-15-2008 06:18 PM
pic: The Aluminum Magnet Travis Hoffman Extra Discussion 7 04-07-2007 08:50 AM
Advice on drilling through hardened steel? ThetaDot Technical Discussion 10 02-28-2004 04:18 AM
Many thanks to Clark Magnet School (696) Greg Ross Thanks and/or Congrats 2 06-04-2003 10:20 PM
Latheing an earth magnet Justin Stiltner Technical Discussion 0 06-27-2001 09:59 PM
