#61
Re: 2010 Silicon Valley Regional
Regardless, the cause is the same; the ball counter working the wrong way. Every time I've seen it happen it was corrected (either based on the authority of n people other than myself who caught it, or the authority of a volunteer counting the in/out manually). |
#63
Though i have to admit it got pretty hard at times, 8 out of the 16 matches the kicker malfunctioned and stuck out of the robot, blocking the rollers, leaving me with a tiny bit of intake on each side of the kicker to work with. |
#64
There is no standard of inspection for breaking the plane
in the rules, other than to eyeball the plane. When robots are suspended from the top it is easy to eyeball the plane. Eyeballing the plane is difficult for robots that hang on the vertical pole if they slip down the pole and make contact with the plane, removing the air gap that would otherwise exist. The lower hanging clamp on our robot was clearanced the day earlier in order to produce a more reliable latch on the top clamp, given the bump in the carpet as you approach the tower that we had not replicated in testing at our shop. This produced the angle for the lower clamp. We added "feet" of 1 inch box tubing, but neglected to make sure that these feet did not extend past the platform. The head ref made the right call in the elimination match and clearly paid a lot of attention to this issue during the eliminations as would be expected once it was realized just how tough this particular call is. The earlier call that "missed" the problem is not relevant to making the correct call in the elimination matches. The best alliance won SVR and the alliance that eliminated our alliance earned their move up the elimination ladder. It is as simple as that. We move on to the Sacramento regional next and we will most certainly have re-worked our hanging clamp to remove this issue, among other re-works that are also in order. See you guys at Sacramento! Eugene Last edited by eugenebrooks : 03-21-2010 at 02:13 AM. |
#65
All in all this was a great event! I had an awesome time.
Thanks to our alliance partners 1868 and 675. The 675 crew is really cool. Very enthusiastic and dedicated group of people. It was an honor to play with you guys again. Too bad we never got up the ramps. Ah well, there's always CalGames. I think I drove everyone on my team crazy with that cowbell you gave me. Also thanks to 1868 for the pick! Robot was a good striker, and a tough machine. I was very proud of the way our alliance performed in the finals. Despite the odds, we managed to tie the red alliance in the first match and put up high scores in the following matches. Team 971 is pretty amazing. Their robot is proof that good ball control is the key to winning. Even without a functioning kicker or a hanger they were able to easily score 10+ points single handedly. Congrats guys. |
#66
I have to say, this was an incredible event. If you had told me my first year, when our robot could barely move, that one day we would be team captains for 3rd alliance, pick the legendary team 100, and almost beat 254 in finals.... I wouldn't have paid attention. I wish they would give "Most Spirited Alliance" Awards instead of just team ones. We would've won for sure. Congratulations for the win at San Diego and have a great time at Championships! We wish we could join you. ![]() |
#67
Are there any pictures of the Poofs or 971 floating around? I'm dying to see them.
Video would also be more than acceptable. ![]() |
#68
#69
(i would watch out for those jag's if i were you) |
#70
#71
Loved the Poof's bot too, and they're only going to get better...I predict they'll get 2-3 in auto consistently by champs, and hang even faster (if that's possible). And how about 649? I can't believe they lasted all the way back around with they way they were driving and the defense they played. A steal of a pick, and the perfect partner to round out that alliance. Big congrats to MVRT 115 on the RCA. I don't know you guys all that well, but it sounded well deserved. |
#72
The jaguars didn't exactly break. They would work intermittently, which is in some ways worse. I'm not exactly sure what the problem was. Scott was noticing that the problem was getting worse and worse as the qualification matches went on. We finally correlated that during a match, Scott hit the wall and pushed against it in high gear for a tiny bit to grab a ball. When he tried to back up, one drive side immediately started acting up. It seemed like the Jags had trouble with the momentary high current draw that was caused by pushing against the wall, and then waited for a second or two before coming back to life. So, we'll be using Victors in our drivetrain and with our other high current motors from now onwards.
#74
The Jaguars are rated for 40A continuous, 60A for 2 seconds and 100 peak. |
#75
We put on a decent performance after that for our last three qualifying matches. Given our trouble moving cleanly for the first seven, it's not much of a surprise if any team found us risky as an alliance pick. (We also had a rather embarrassing issue: a metal staple found its way into our digital sidecard, occasionally shorting it out. Oops... Thanks to Kiet of 254 for finding it and pulling it out for us. It was jammed in there good.) Anyway, IMO, a more proper solution to this would have been to limit how fast the motor could change speed in software, instead of swapping to Victors. |
| 2010 Silicon Valley Regional | unobtainium-42 | Regional Competitions | 7 | 11-29-2009 08:46 PM |
| Silicon Valley Regional Update | Jason Morrella | Regional Competitions | 0 | 02-21-2006 12:04 PM |
| Silicon Valley Regional | whakojacko | Regional Competitions | 41 | 03-28-2005 12:58 PM |
| Silicon Valley Regional | Alaina | Regional Competitions | 21 | 03-25-2003 12:47 AM |
| Silicon Valley Regional | Dima | Regional Competitions | 2 | 03-27-2002 04:23 AM |
