Go to Post These awards aren't easy to get, and if a team deserves an award, they deserve to be cheered on for it. - tckma [more]
VEXpro
Chief Delphi Alumni
ADVERTISEMENT
Unread 08-18-2010, 10:27 AM
Clem1640 Clem1640 is offline
FRC #1640 (Sab-BOT-age)
Clem1640 has much to be proud ofClem1640 has much to be proud ofClem1640 has much to be proud ofClem1640 has much to be proud ofClem1640 has much to be proud ofClem1640 has much to be proud ofClem1640 has much to be proud ofClem1640 has much to be proud of
pic: CAD exercise - 1640 Pivot Assembly with cut-away view of Pivot Module
Unread 08-18-2010, 10:28 AM
ttldomination's Avatar
Sunny
AKA: Sunny
FRC #1648 (G3 Robotics)
Re: pic: CAD exercise - 1640 Pivot Assembly with cut-away view of Pivot Module
If I may ask, which program did you use to make this? And did you use a special feature to make the chains?
- Sunny
1648: 2013-????
Unread 08-18-2010, 11:01 AM
Broadcast Eng/Lead Robot Inspector
AKA: Big Al
FRC #0111 (WildStang)
Clem,
A very nice drawing, you sure are getting the hang of using Inventor. Do you have an exploded view worked out yet? Keep up the good work!
Al
WB9UVJ
www.wildstang.org
________________________
Season Eighteen, what a spectacular year! It's has been a bumpy ride. All is better now, new parts are working fine. Champs were spectacular!
Unread 08-18-2010, 01:34 PM
Division By Shaker?
FRC #2791 (Shaker Robotics) (EWCP))
Team Role: Tactician
I like a lot of things about your modules this year. Two chain reductions instead of a transmission, the triangle gussets on the sides of the module for stability, the dead axle with extra nuts instead of spacers at the bottom, and using an axle as a structural member of your module. Nice job!
Proud 2791 Mentor (2010-201?) - 2012 BAE Granite State Regional Finalists (with 1519, 885), 2013 WPI Regional #1 Seed / Finalists (with 20, 3182), Beantown Blitz Finalists (with 2168, 4564)
Proud 1714 Alumnus (2009) - 2009 Minnesota 10,000 Lakes Regional Champions (with 2826, 2470)
My Robotics Blog (Updated Mar 15, 2012... I know, I'll get to it.)
Unread 08-18-2010, 01:52 PM
AKA: OUTWORK US
FRC #0973 (GRR)
Is that #25 or #35 chain?
2011 World Champions
Follow 973 on twitter, @FRC973
Like our Robots? Check out the CAD files of ALL our robots!
Unread 08-18-2010, 06:29 PM
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1 Send a message via Skype™ to jspatz1
I am very surprised that you did not have trouble with the cantilevered side-load on the Denso motor shaft. The worm gear in that motor is a plastic gear captured only by the thin sheetmetal lid on the housing, and is not designed for any side-load whatsoever. You might want to consider supporting the end of that sprocket if you can. We have found that a 5/8" OD ball bearing fits nicely into the center hole of the plastic Denso adapter to provide end support.
I very much like the chain reductions and overall design of your module. Very similar to our own.
Unread 08-19-2010, 07:10 AM
Gdeaver Gdeaver is offline
FRC #1640
Inventor was used to model the whole robot. The chains are #35. We have not had any problems with the steering motors from the sprocket not being supported on 2 sides. We have had major problems with the Denso window motors. The locking pins caused some serious drag when not run at full speed. We removed the locking pins and the denso motors worked much better in this steering application. Even with the pins removed, we had random motor shut down. We removed the jags and substituted victors. Since we went to victors we have not had any problems with the Denso units. Denso and jags do not mix. The over all design has worked very well. However we are working on several design tweeks in the off season. One thing that gave us problem were set screws constantly loosening. The next iteration will not rely on sets screws.
Unread 08-19-2010, 07:39 AM
Brandon Holley's Avatar
I think we all learn this lesson once before we wise up and nix set screws from our designs. Its a right of passage of a FIRST team.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2011 Bayou Regional Finalists (3rd seed), Innovation in Control Award
2011 Boston Regional Finalists (2nd seed), Industrial Design Award
2012 New York City Regional Winners
2012 Boston Regional Finalists (2nd seed)
2013 Orlando Regional Finalists (2nd seed), Industrial Design Award
2013 Boston Regional Winners (1st seed)
Unread 08-19-2010, 08:12 AM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Send a message via AIM to Alan Anderson
That observation seems worthy of a tangential discussion. We haven't used window motors for anything lately, so I can't comment, but I'm very curious. Are there any other teams out there who had a similar (or contradictory) experience using them with Jaguars?
Unread 08-19-2010, 10:04 AM
Siri's Avatar
Siri Siri is offline
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
Indeed, in fact there's been a rather interesting discussion about it already, if you're interested. EDIT: Gary's got it.
Team 1640: Sab-BOT-age Downingtown Area Robotics
Newton CHAMPIONS 2013 - Mid-Atlantic Champions 2013 - Mid-Atlantic Champions 2012 - Philadelphia Regional WINNERS 2011
2013 Season: Ref & Inspector. Coaching Horsham, Chestnut Hill, MAR Champs, Newton & Einstein
Field Coach, Co-Lead Design Mentor, Pit Supervisor
Unread 08-19-2010, 10:05 AM
FRC #1640
There is a thread on the Jag and Denso problem.
http://www.chiefdelphi.com/forums/sh...ad.php?t=83973
We have not responded to this thread since removing the locking pins. Even with the locking pins removed, we experienced random Denso shut down. For IRI we swapped out the jags for victors and the problem has disappeared. The window motors are great without the locking pins and victors. We have no hard data to help with why the Denso's overheat while under very light load with the jags. I think it has something to do with the high switching frequency of the jags interacting with the PTC causing it to self heat. I would like to see First allow the removal of the locking pins. Its easy and improves the performance of the motors. However, The bypassing or removing the PTC is much more questionable. It's an actual modification of the motor. So if you use the window motors, use victors.
Unread 08-19-2010, 01:59 PM
AKA: OUTWORK US
FRC #0973 (GRR)
You could definitely get away with #25 chain on the initial reduction, and possibly on the final reduction as well.
Unread 08-19-2010, 03:33 PM
Software Architect
Thanks. I don't regularly follow the Motors forum, so I didn't know so much attention had already been applied to the subject.
Unread 08-19-2010, 08:39 PM
We have not had any problems with the cantilever loading on the window motor sprocket. We are still using the original (4) window motors after (6) competitions (on & off-season) and (4) demos. We've got (L&R) spares, but have not needed to replace any originals yet.
We embed a magnet in the end of the sprocket. A Cherry absolute magnetic encoder is mounted on the plate below the sprocket. This encoder provides information on the sprocket angle and (since the drive sprocket on the motor and the driven sprocket on the pivot are both 15T) therefore the pivot angle. This makes mounting the bottom end of the drive sprocket problematic.
Regarding building chains in Inventor, I have a process which works well (albeit a little tedious). I will write this up (it'll be short).
Clem McKown
Head Mentor - FRC Team 1640
Chairman - Downingtown Area Robotics
2011 Philadelphia Winner & 2nd Seed
2011 Rockwell Automation Innovation in Control Award (Philadelphia)
2010 Xerox Creativity Award (Philadelphia)
2009 Rockwell Innovation in Control Award (Chesapeake)
Unread 08-20-2010, 02:44 AM
Aren_Hill's Avatar
definitely didn't tone it down
FRC #3928 (NEUTRINOS, 1625 alum/mentor)
I can picture it now
pit visitor: "Why'd you use #35 chain?"
team member "less links to CAD...."
Because robots
pic: 1640 Pivot Module Clem1640 Extra Discussion 11 08-04-2010 11:47 PM
pic: 2228 Cougar cut on to sheetmetal (CAD) jamie_1930 Extra Discussion 11 05-09-2010 06:29 PM
pic: 1640's 2010 Pivot Assembly Gdeaver Extra Discussion 8 02-10-2010 07:11 PM
pic: Swerve Module Concept (View 2) Dave McLaughlin Extra Discussion 5 06-16-2009 11:15 PM
pic: Swerve Module Concept (View 1) Dave McLaughlin Extra Discussion 15 06-16-2009 09:36 PM
