Go to Post Hey, those kind of thoughts lead to thick rulebooks!;) - David Brinza [more]
Go Back   Chief Delphi > Technical > Programming > WindRiver C++
VEXpro
ADVERTISEMENT
Unread 11-01-2010, 02:28 PM
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
WATCHDOG!!
Is it safe to set the watchdog expiration to 2 minuites and 15 seconds??
Unread 11-01-2010, 02:29 PM
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
436f6465206765656b
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8 Send a message via Skype™ to demosthenes2k8
Re: WATCHDOG!!
If that's the case you might as well just disable it.
GSR Dean's List Finalist 2011
Unread 11-01-2010, 02:33 PM
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
Re: WATCHDOG!!
I did, but set turned on because when ever our robot kicks, and I recharge it while driving, it will go out of control untill the robot is fully charge, so if we were going forward the robot will keep going forward untill the kicker is fully recharged. so I am wondering if it has to do with the fact that the watchdog is disabled
Unread 11-01-2010, 02:46 PM
EricVanWyk EricVanWyk is offline
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Re: WATCHDOG!!
Originally Posted by krudeboy51 View Post
I did, but set turned on because when ever our robot kicks, and I recharge it while driving, it will go out of control untill the robot is fully charge, so if we were going forward the robot will keep going forward until the kicker is fully recharged. so I am wondering if it has to do with the fact that the watchdog is disabled
It sounds like the code that recharges your kicker is "blocking" - that is, it takes control and doesn't let other code execute while it is busy. You need to rewrite your kicker recharger so that it doesn't do this.
I'm guessing that when you first wrote the recharger, the watchdog would immediately trip and shutdown the robot... so you disabled it. Now you have unsafe robot!
Whenever you disable the watchdog because it finds an error, you are just giving yourself an extra problem and making the original error worse. I have yet to see an error where disabling the watchdog was the correct decision.
Unread 11-01-2010, 02:58 PM
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
Re: WATCHDOG!!
We basically disabled it because during build season, when we leave the robot on for a while it would show that the watchdog is not being fed. At that time we did not have this problem
Unread 11-01-2010, 04:29 PM
Tom Line Tom Line is offline
Autonomouse
FRC #1718 (The Fighting Pi)
Re: WATCHDOG!!
I'm guessing that you're trying to use a loop of some sort in your recharge code.
Loops are not necessary 99% of the time in coding FIRST robots - after all the code already loops at between 20hz and 50hz.
Loops monopolize the processor and will not allow it to move on and "feed the watchdog", unless of course your feed statement is inside the loop.
Team 1718 LabView Tutorial
Unread 11-01-2010, 04:37 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: WATCHDOG!!
Did you understand what Eric was explaining about the recharge code blocking execution? If not, it's worth talking it through until you understand it, and the proper way to design code so that it does not do this. The people here will help you. Ask questions.
Unread 11-01-2010, 07:19 PM
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: WATCHDOG!!
Hence forth to be known and the VanWyk Axiom
He who started the hashtag #omgChiefDelphi
Watchdog kgzak NI LabVIEW 6 03-10-2010 02:36 PM
Watchdog Issues Kyledoo WindRiver C++ 4 02-23-2010 11:31 PM
Watchdog!?!?!?! NC GEARS General Forum 38 01-23-2010 07:52 AM
Watchdog darty NI LabVIEW 8 02-16-2009 08:11 AM
Watchdog Barchechath Programming 6 02-10-2007 07:05 PM
