KOP Speculation
This year's KOP is a little different from previous years.
Any thoughts on what they could be? Does this have anything to do with speculation of tethered robots or a train-related game? Community, what do you think? |
Re: KOP Speculation
Special wheels/mechanisms for rails? like roller coasters? haha just... speculating
Re: KOP Speculation
Deflated game objects, miniature motors, the FedEx donation, or some such small item. The Mabuchi motors were loose outside in at least one year, for example. Depending on the game object, it might be possible to get one under paperback size.
The tote seems like the standard size, but it's likely to be better filled this year (and some of the past ones were packed tight, some were very loose). The long box is the Kitbot, if tradition holds. |
Re: KOP Speculation
probably not the fed ex donation... that's called out specifically further down in the e-mail:
Re: KOP Speculation
Servos? Jaguars?
Re: KOP Speculation
jaguars are like half a pound each so i doubt it. may be they contain a flux capacitor and plutonium
or maybe they contain lead weights |
Re: KOP Speculation
I'll give you my prediction in just over 35 hours.
Re: KOP Speculation
Isn't that the standard tote size? With the Choice program, probably all standard KoP items fit in one tote this year; it might be a little heavier than when all the previously-supplied items would be divided between 2 totes. Motors are probably the majority of the weight. (Remember, past rules specified that except for any additional CIM's allowed, motors used on the robot had to be from the current KoP.)
Separately packaged items are usually those that arrived too late to put into the tote. Probably the size and weight is that of the largest one. I wouldn't read too much into this. Last edited by GaryVoshol : 01-07-2011 at 07:17 AM. |
Re: KOP Speculation
Perhaps the smaller boxes are CIM motors donated in their own packaging? Maybe some new Electronics gear that FIRST didn't want to package in with the rest of the KOP? Those are the only things that come to mind that are that small but also that heavy.
Or, OMG, what if they give us one of each (if there are multiple) or more than one game piece? That'd be something right there. (For those of you that weren't around in 2009, finding replacement game pieces was nearly impossible unless you were adventurous enough to go through every Walmart in the surrounding area and search through the clearance Aisle, and in 2010, we realized that not all size 5 soccer balls were created equal...) |
#10
Re: KOP Speculation
#11
Re: KOP Speculation
.But Sirusly, I'm surprised were going down to 1 bin for Veterans... |
#12
Re: KOP Speculation
They've been talking about reducing the kit size for Veterans for the last year or two. I can't remember if we got two bins last year or not, but I know whatever it was - it wasn't much. Some vendors are reducing what they're putting in the KOP or making it available to those teams that request it to keep the cost down. You've also got to figure that a New Control System takes up nearly a tote in itself between the CRio, Assorted Modules, PDB, Digital Side Car, etc.
#13
Re: KOP Speculation
Re: KOP Speculation
Last year was two just-over-halfway-filled totes for the veterans.
#15
Re: KOP Speculation
Lets also keep in mind that most years we've gotten small/delicate parts in their own packaging or envelops. One great example is the accelerometer and Gyro. small padded envelop, smaller than a book and less than 5 lbs. Remember, we have an upper limit on weight, not a lower limit - so don't discount the jaguar theory, h1n1is4pigs. Half a pound is still less than 5 lbs.
| KOP | Jack Gillespie | Pneumatics | 3 | 01-31-2010 05:13 PM |
| 2006/2007 FVC speculation? | Billfred | FIRST Tech Challenge | 24 | 09-13-2006 12:26 PM |
| KOP photos? | Gary Dillard | Rumor Mill | 13 | 01-04-2006 07:56 PM |
| 8 days before we know....Where's all the speculation!? | archiver | 2001 | 3 | 06-23-2002 09:11 PM |
| Isn't it about time for some speculation? | archiver | 2000 | 0 | 06-23-2002 09:05 PM |
