capping the tower
I was curious if people think capping a tower with a tube would be legal or not.
Re: capping the tower
Are you asking if a tube gets tossed from the human player position and it accidently gets hooked around the tower? Or are you asking if you can cap it intentionally?
prohibited. Violation: RED CARD |
That rule is in the End Game section.
my bad. i dont see anything against it, but that would be really hard and they still would have (18) minus (laying sideways height of tube) inches for deployment room. and if you put a bunch over their tower actually scoring them would benefit you more.
Intentionally. Basically it comes down to are whether or not actions done in the teleop period applicable to penalties in the endgame period
I don't believe there is any rule governing it.
Before we go any further, is there a why behind this? |
Assuming your minibot is 12" big you would have a 6" window to place it, also you couldn't place it on the base, which may be some teams strategies. blocking a potential 50 points would have drastic implications
I don't think it would have any effect other than blocking the lights on the top and annoying the field crew who has to retrieve the tube that's now >10' in the air. And keeping a tube out of play.
Is it possible to do? I think so. But I also think that risk/reward just ain't in favor of doing so. I'd personally (and I'm not a ref) call putting a tube over the tower as intentionally blocking deployment via pole contact, if it made it to the bottom. That's not a light penalty, either. |
#10
Sounds like a good question for the Q&A!
#11
<G23> covers opposing towers, and (unless it's within the last 10 seconds) you can't break the plane of the base of the tower without penalty (can't find that rule, but it was specifically called out at kickoff).
#12
The round tubes have a diameter of 12" and are flexible, the disks at the top of the poll are 12" too. This means that potentially the disk could fall down the to the bottom.
#13
Also G23 is only covered by the end game, not the teleop period. |
#14
1) Field reset will want to do mean things to you. They have to remove the tubes. 2) If I were the head ref, I'd see intentional blocking. Boom, red card. See that blue box below <G24>? It's not a rule, but it does say something about throwing tubes at minibots climbing. I'd figure on that being enough to pull the card; you are interfering with deployment. |
#15
if it was done, i'd assume the same rule for minibot would apply, you got them on, you have to get them off. |
