BaneBot gearboxes out of stock...
So today when I tried to order the 20:1/26:1 gearboxes [for the 550] today I realized both are out of stock...
After calling banebots and getting no answer, anyone know how long before they get back in stock? |
Re: BaneBot gearboxes out of stock...
Banebots will be the only one to answer that question. I can provide some related answers you might be interested in, however. Namely, what other options you have.
Andymark has the GEM500 gearbox 13:1 2-stage, 49:1 3-stage. Or the PG-71 gearbox at 71:1. From Banebots, you could buy all the P60 parts individually and assemble the thing yourself. It's about $25 more expensive (Crazy, I know). I can post a list of all the necessary parts for a 20:1 or 26:1 gearbox if anyone's interested. In my search for gearbox alternatives last year, I came across some possibilities that I've yet to try. WARNING: These look like they interface to an RS-500/550 based on the gearbox drawings. I can't guarantee that, nor do I know anything about the robustness or reliability. Most have the motor attached, so you'll need to press the pinion off the shaft or find a new pinion somewhere. Robot Marketplace PK27 (27:1) (sounds spur gear, less robust) Robot Marketplace PD27M (27:1) (planetary, more robust) Also possibilities if you can find somewhere to buy them: http://www.mfacomodrills.com/gearboxes/942d_series.html Or any gearbox/motor off this page: http://www.kysanelectronics.com/Prod...p?recordID=247 |
Ran into the same problem a couple days ago. Those gearbox's are not listed on the FIRST team list of parts. We recalcalculated our need and switched to 775 motors and gearbox's that BB showed available. I would not trust them to get an out of stock order to you in time.
That brings up another possibility. Order a 775 gearbox plus the correct 550 rear block, mounting kit, and pinion. Still more expensive than ordering exactly the gearbox you need, but a little simpler than ordering all the individual pieces.
Based on the relatively low price of the 32DP gears that Robot Marketplace lists, I suspect that we'll be self-building the three ~26:1 gearboxes we need. We had planned on using several the P60 26:1 but learned of the backorder status earlier today (independant confirmation). Sigh.
I just got a few 16:1's and plan to reduce them further. Shouldn't be too bad for now until I can get a shipment of 20:1's in.
This is bad news...
I know of a few of the other solutions but we would really rather not have to go moding drill motors or something. I hope they get some stock soon.. |
An interesting update from BaneBots:
We got our order of 11x 20:1 p60's in today, made sure to order early
#11
Classic Banebots. Will they ever learn that the demand rises hugely during FRC season?
#12
Time to start moding those drill motors....
BaneBots are really mainly BANE |
#13
We have a lot of new, unopened cimulators if anyone needs them down the road.
We also have a surplus of used 4:1s if someone was really in a pinch. |
#14
I don't know your specific application, but wouldn't 16:1 be comparable to those other 2?
#15
But the difference is about 1000 vs 650 RPMS. |
