Go to Post One of the cultural concepts that has emerged from the teams participating in FIRST is that ideas are worth sharing. - Alan Anderson [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Team 221 LLC
ADVERTISEMENT
Unread 01-25-2012, 12:21 PM
Cheeset2 Cheeset2 is offline
FRC #4254
Cheeset2 is an unknown quantity at this point
Smile Help?-Vex pro Spike Switch?
Dear Interwebs,
This is team 4254. This is our rookie year and we need a little help with programming. We have a two person programming team and we both know java from high school courses. We have our robot driving around but we are having difficulties programming the Vex Pro Spike switch. Please help us!
Thank you.
Unread 01-25-2012, 03:21 PM
FRC #4254
Re: Help?-Vex pro Spike Switch?
I realize that i gave no info about our problem, but we really have nothing done. We have tried many things but none of them have worked and i think if we just saw an example of code that worked it would help us out a boat load
Unread 01-26-2012, 09:20 AM
eddie12390 eddie12390 is offline
Well, at least it isn't on fire...
Rookie Year: 2000
eddie12390 is an unknown quantity at this point
Import the Relay class
Code:
import edu.wpi.first.wpilibj.Relay;
Create a Relay object (I'll call mine Tom)
Code:
Relay Tom = new Relay(PORT YOU PLUGGED THE PWM WIRE INTO ON DSC);
The code to turn the spike on is something like
Code:
Tom.set(Relay.Value.kForward);
I'm not at a computer with the SDK but I'll check with the JavaDocs to make sure this is correct in a moment.
Edit: After a quick check this seems correct. To disable the relay, use this:
Code:
Tom.set(Relay.Value.kOff);
Unread 01-26-2012, 10:28 AM
FRC #4254
Code:
Code:
Code:
Code:
Thank you very much. We will be sure to try that when we get our connection to the robot back....
Unread 01-26-2012, 01:11 PM
FRC #4254
Code:
Can you please explain this part of your code in more detail?
Specifically the PORT YOU PLUGGED THE PWM WIRE INTO ON DSC part.
Unread 01-26-2012, 04:25 PM
cgmv123's Avatar
cgmv123 cgmv123 is offline
Professional Peon
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Team Role: Electrical
Rookie Year: 2011
cgmv123 is a splendid one to beholdcgmv123 is a splendid one to beholdcgmv123 is a splendid one to beholdcgmv123 is a splendid one to beholdcgmv123 is a splendid one to beholdcgmv123 is a splendid one to beholdcgmv123 is a splendid one to behold
Code:
There are 8 relay ports on the sidecar. They are numbered from 1-8. The number corresponding to the port you plugged the PWM cable from the relay into the sidecar replaces the "PORT YOU PLUGGED THE PWM WIRE INTO ON DSC" in the code.
The rest of the code just initializes the relay using the port. Everything is an object.
I don't get it. We followed all the instructions exactly. Why doesn't it work?
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2013 FIRST Championship Curie Division (#breakthecurse)
2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division
2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson), Semi-Finalist (1732/1714)
2011 Wisconsin Regional Innovation in Control Award
Unread 01-26-2012, 10:21 PM
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a jewel in the roughotherguy is a jewel in the roughotherguy is a jewel in the roughotherguy is a jewel in the rough
The ones in red are the relay ports
http://team2168.org
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
