Go to Post Would all you teams please stop! My chin will be bruised for weeks from dropping on the floor so much. - GaryVoshol [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Chief Delphi Alumni
ADVERTISEMENT
Unread 01-30-2012, 08:50 PM
joelg236's Avatar
joelg236 joelg236 is offline
- Lead Programmer -
AKA: Joel
FRC #4334 (Alberta Tech Alliance)
Rookie Year: 2012
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
New to FRC programming... How does this look?
I am completely new at FRC programming, and I'm not sure what really is the best way to go about it. Anyone care to give suggestions?
Code:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.*;
public class RobotTemplate extends IterativeRobot {
    public RobotDrive drivetrain;
    public Joystick leftStick;
    public Joystick rightStick;
    public Joystick KTrigger;
    public Gyro gyro; //gyro
    public Watchdog getWatchdog;
    public void robotInit(){
        drivetrain = new RobotDrive(1, 2, 3, 4);
        leftStick = new Joystick(1);
        rightStick = new Joystick(2);
        KTrigger = new Joystick(3);
    public void autonomousPeriodic(){
        getWatchdog.kill();
        int x = 1;
        do{
            gyro.reset();
            int i=0;
            while(i<4){
                drivetrain.drive(0.5,0.0); //START GOING STRAIGHT
                Timer.delay(4.0);
                drivetrain.drive(0.0,0.0); //STOP
                Timer.delay(4.0);
                gyro.reset();
                double angle = 0;
                do {
                    drivetrain.drive(0.0, 0.15); //TURN
                    Timer.delay(0.5);
                    angle += gyro.getAngle(); //
                    gyro.reset();
                    log("Gyro reads "+angle);
                }while(angle<90); //Keep going in increments of .15 until gyro returns more than 90 degrees
                Timer.delay(4.0);
                i++;
        }while(x>0);
        getWatchdog().kill();
        while (isOperatorControl() && isEnabled()){
        Timer.delay(0.002);
                while(KTrigger.getTrigger()){
                    Timer.delay(1.0);
            double leftYAxis = leftStick.getAxis(Joystick.AxisType.kY);
            double leftXAxis = leftStick.getAxis(Joystick.AxisType.kX);
            double rightYAxis = rightStick.getAxis(Joystick.AxisType.kY);
            double rightXAxis = rightStick.getAxis(Joystick.AxisType.kX);
            double powerValue = ((leftXAxis+rightXAxis)/2); // FIND RIGHT CALCULATION FOR 0-100% (0.0-1.0)
            double turnValue = ((leftYAxis+rightYAxis)/2);//FIND RIGHT CALCULATION FOR 0.0-1.0
            drivetrain.drive(powerValue,turnValue);
    public static String log(String aMessage){
        System.out.println(aMessage);
        return aMessage;
Unread 01-30-2012, 09:19 PM
Djur's Avatar
Djur Djur is offline
I Java.
AKA: Sam Carlberg
FRC #2084 (Robots by the C)
Djur will become famous soon enough
Re: New to FRC programming... How does this look?
  • You need to initialize all used objects in RobotInit() -- You're calling data from the gyro, but it's never been initialized, so you'll get Null Pointers from that; same for your Watchdog.
  • You don't need to use the watchdog class.
  • During teleopPeriodic: Timer.delay(0.002) only slows down the robot, same for Timer.delay(1.0) -- it makes that thread sleep and you can't do anything until it wakes up. You'd be better off using if(KTrigger.getTrigger())drivetrain.drive(0,0);} -- Since teleopPeriodic is looped anyway, the "while" loop is redundant.
Just some quick suggestions
"Wow." - Dean Kamen on 2084's Rebound Rumble 'bot.
Finalists in the 2012 Boston Regional with 125 and 78
LiveWindow, RobotBuilder, and WPILibJ developer.
Unread 01-31-2012, 06:17 PM
joelg236's Avatar
- Lead Programmer -
AKA: Joel
Rookie Year: 2012
Thanks so much for the help
Look better?
Code:
    public Joystick joystick;
        joystick = new Joystick(1);
        KTrigger = new Joystick(1);
        gyro = new Gyro(1);
    public void autonomousContinous(){
        int x = 1;
        do{
            gyro.reset();
            int i=0;
            while(i<4){
                Timer.delay(4.0);
                Timer.delay(4.0);
                gyro.reset();
                double angle = 0;
                do {
                    Timer.delay(0.5);
                    gyro.reset();
                Timer.delay(4.0);
                i++;
        }while(x>0);
    public void teleopContinous() {
                {drivetrain.drive(0,0);
                log("Brake enabled");}
            double YAxis = joystick.getAxis(Joystick.AxisType.kY);
            double XAxis = joystick.getAxis(Joystick.AxisType.kX);
            drivetrain.drive(YAxis,XAxis);
        return aMessage;
Unread 02-01-2012, 10:53 AM
eddie12390 eddie12390 is offline
Well, at least it isn't on fire...
Rookie Year: 2000
eddie12390 is an unknown quantity at this point
This may just be one of the things that I do and find useful, but creating constants for port numbers can be extremely useful for someone who has not read your code and is not using your robot.
Things like
Code:
private static final int DRIVE_LEFT_FRONT = 1;
Jaguar frontLeftDrive = new Jaguar(DRIVE_LEFT_FRONT);
will be a lot easier for others to understand. (And when you want to make a change you can just find your constants and type in a new number)
Also, to find the x axis/y axis value just type joystick.getX() or joystick.getY(). You also do not need to set the value of the joystick to a double before supplying it to the drive() method.
Code:
        return aMessage;
The above would probably just be better off as a void where you don't have to bother with the return type. You'll just be telling yourself something that you already know.
Unread 02-02-2012, 09:12 AM
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a glorious beacon of lightomalleyj is a glorious beacon of lightomalleyj is a glorious beacon of lightomalleyj is a glorious beacon of lightomalleyj is a glorious beacon of lightomalleyj is a glorious beacon of light
Code:
double angle = 0;
do {
     drivetrainTimer.delay(0.5);
     gyro.reset();
I don't use the standard drive() methods, but IIRC the first value is the forward speed and the second the turning offset speed-wise, not an angle. So unless you know 0.5 second increments is going to end up close to 90, you could be over by a bit.
And only reset your gyro when you need to, and not when its moving. You want to stop and wait a little so that you have a steady zero value.
Unread 02-02-2012, 09:36 AM
neal's Avatar
neal neal is offline
Neal
FRC #1777 (Viking Robotics)
neal is an unknown quantity at this point
Like omalleyj said, resetting gyro in the loop isn't a good way, especially when it's moving.
I would do something simple like this:
Code:
// Reset gyro before the main loop, or with a button.
double angle = gyro.getAngle();
if (angle < 90) {
    drivetrain.drive(0.0, 0.15); // I don't know how turn works, I've only done tank drive and mecanum drive in the past.
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
