Axis Camera Stream without cRIO
Hi guys-
We have 2 Axis Cameras this year, one connected through the bridge to the cRIO for image processing, and we plan on using the other one for a live stream for driving assistance. How do we set this up, so even if the cRIO isn't powered we could still view the stream in the driver station? |
Re: Axis Camera Stream without cRIO
Put one camera on 10.17.71.11
The other on 10.17.71.12 Plug both into the DLink. Devise a way to give both 5v power feeds on the robot. Create a Dashboard project and change the camera IP address to 10.17.71.12 If you want both cameras displayed on the Dashboard, then you can duplicate the code for the original camera and change that IP address to the 2nd camera. |
One camera with the .11 address is all you need to give you all these features. The live stream on your dashboard is independent of the crio.
BTW, you can have a batch script that runs when the classmate logs in that pulls up internet explorer. Then just set the homepage to the webcam that you want to use for drive.
If the cameras are in the same position you are much better off just using one and piping the results back to the driver station after processing, as said in the post above. Be weary of port rules. There are a couple of threads explaining odd network setups and rules that follow. Also the camera takes up a lot of bandwitdth... |
Also, we don't know LabView very much, (we can open the program and pull up an example), how do you change the value on the camera dashboard? Thanks! |
To modify the dashboard, launch LabVIEW and on the intro screen, choose to make a dashboard from the template. After it opens, you can add any indicators you like including duplicating the vision display and the loop that reads the second camera. You also need to update the IP for the second loop.
Greg McKaskle |
Hard to describe if you don't even know the basics of how to wire in LabVIEW.
Are your cameras pointed in different directions? I assume that is the only reason to have more than 1.
yes one is for tracking one for driving, pointed in different directions. don't want to load up the c-rio with the driving camera.
#10
A simple way to do this is to just navigate to the IP of the camera (10.17.71.12) in your browser.
Last year, we did this at the last minute for the camera aiming the minibot, and for aiming the minibot launcher, we just stuck a piece of black electrical tape on the computer monitor for aiming. |
#11
