Go to Post "well.. I think I underestimated the swine..." -Andy Baker - Joel J [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ITT Tech
ADVERTISEMENT
Unread 02-13-2012, 07:29 PM
Wildcat Robotic Wildcat Robotic is offline
FRC #3039
Wildcat Robotic is an unknown quantity at this point
Camera loses connection when configured with Robot Radio
Hello!
We had everything set up, was able to track the vision target also... But suddenly one day when we tried to hook it up to the robot, things didn't work out quite as we thought it would. The Axis 206 camera lights up green when configured with 8-slot cRIO, but once we try to set it up with Robot Radio with team number 3039, it doesn't work! Out Robot IP is 10.30.39.2 and our Computer IP is 10.30.39.9. Any help out there?
Unread 02-13-2012, 08:06 PM
Mark McLeod's Avatar
Itinerant Programmer
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Camera loses connection when configured with Robot Radio
Did you use the Axis Camera Setup tool?
The latest one in Utilities Update 2.0?
Try pinging the camera at 10.30.39.11 to see if you can successfully reach it.
Try pinging 192.168.0.90 too.
"Always exaggerate. It makes life seem more interesting." - Robert Weber
Unread 02-13-2012, 08:13 PM
FRC #3039
Yes we have used the latest Axis Setup Tool. We set it up with the IP 192.168.0.11 and subnet mask 255.255.255.0 but we can't reach the camera when it's set up using Robot Radio. IT gets a green light when using 8-slot cRIO but that's not what we want to use.
Unread 02-13-2012, 08:37 PM
The Robot Radio expects the camera to be at 10.30.39.11.
Unread 02-13-2012, 08:51 PM
FRC #3039
Yes, I know, but that was our PC config. We have tried to set it up with the Axis Setup Tool several times on Robot Radio and it doesn't work. Will a manual setup work? The light is amber when it's rebooted when configured with robot radio but it doesn't do it when it's configured with the cRIO
Unread 02-13-2012, 09:04 PM
A yellow status ring probably reflects an incorrect setup for whatever reason.
You can do a manual setup of the camera. Your PC just needs to have a compatible IP address for whatever the camera has now.
This is all the tool does:
  • Creates an administration account of username: FRC, password: FRC
  • Sets the IP to 10.30.39.11
  • Sets the netmask to 255.0.0.0 or 255.255.255.0 (either will work)
Afterwards, your PC needs to be on the same network of course, for the Driver Station it's 10.30.39.5
Unread 02-13-2012, 09:27 PM
FRC #3039
So if I understand you correct:
Set the PC IP and Subnet Mask to 192.168.0.11 and 255.255.255.0
Go to internet explorer and log in using 192.168.0.90 and username+password
Change the IP and subnet mask on the camera to 10.xx.yy.11 and 255.0.0.0
Set Username and Password to FRC and FRC
Connect the camera to the Robot Radio, then reboot the robot
Unread 02-13-2012, 09:44 PM
Some differences:
  1. Reset the camera first to make sure the camera is currently at 192.168.0.90, because you said you'd already used the Tool to try to reset it to 10.30.39.11
  2. I don't think I'd use .11 for your PC, that just confuses things. The PC/Driver Station should be .5, a programming PC at .6, but yes, set your PC to 192.168.0.5/255.0.0.0
  3. Internet Explorer to http://192.168.0.90
  4. After a reset the login is Username: admin, Password: blank
  5. Change the camera IP to 10.30.39.11/255.0.0.0
  6. Create a new user account with Administrator privileges of Username: FRC, Password: FRC
  7. You can already have the camera connected to the Robot Radio on the robot for all this, but you can also connect directly to the PC if you want.
  8. Change the PC IP address back to 10.30.39.5/255.0.0.0
  9. Test reaching the camera at it's new IP address using IE
  10. Bring up the Dashboard to see if it finds the camera.
Unread 02-27-2012, 03:30 PM
CrashOverride's Avatar
CrashOverride CrashOverride is offline
FRC #1831
CrashOverride is an unknown quantity at this point
Does your camera truly loose connection or does it have an all black image?
We found that our camera, when left with auto-brightness control enabled, would eventually go completely black. After the camera is set to 10.xx.xx.11 login to it with a laptop and set auto-brightness to off.
Good Luck!
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
