Go to Post I can neither confirm nor deny that I've worked on alot of pretty cool stuff. - Gary Dillard [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Kettering University
ADVERTISEMENT
Unread 02-15-2012, 07:02 PM
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
Rookie Year: 2012
shuhao is an unknown quantity at this point
100 threads then robot code gets terminated
If i spawn 100 threads, even though only 2 is active at all times, the robot code get terminated.
Why is this happening? And anyone know what the work around is?
Unread 02-15-2012, 07:08 PM
RufflesRidge RufflesRidge is offline
RufflesRidge has much to be proud ofRufflesRidge has much to be proud ofRufflesRidge has much to be proud ofRufflesRidge has much to be proud ofRufflesRidge has much to be proud ofRufflesRidge has much to be proud ofRufflesRidge has much to be proud ofRufflesRidge has much to be proud ofRufflesRidge has much to be proud of
Re: 100 threads then robot code gets terminated
Don't spawn 100 threads?
Unread 02-15-2012, 11:42 PM
Zholl Zholl is offline
EE in training
AKA: Chris Sherwood
FRC #2996 (Cougars Gone Wired)
Zholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to behold
Send a message via Skype™ to Zholl
I would have to agree here. Granted, I don't have much experience in Java, but my experience with other languages has been that if you have too many simultaneous threads of execution, the program slows down until the whole thing times out and crashes
Unread 02-16-2012, 07:31 AM
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Rookie Year: 2012
Chiller is an unknown quantity at this point
Yes that would even happen on non cRio applications such as a game on a computer... Why would you want 100 threads??
Unread 02-16-2012, 11:03 AM
Rookie Year: 2012
I don't have 100 active threads. I just spawned that many over Time. The Max active thread count I have is 2..
Unread 02-16-2012, 11:21 AM
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
What output is reported? Can you try to print out the amount of free Java heap occasionally (Runtime.getRuntime().freeMemory())?
You can also check the number of currently executing threads (including those that are waiting for something), by calling Thread.activeCount().
Unread 02-16-2012, 08:39 PM
Rookie Year: 2012
Ill do the memory count tomorrow. Active thread is 2, as I've been trying to say...
Unread 02-16-2012, 10:48 PM
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
The operating system on the cRIO is vxWorks. The algorithm to select the next task/thread to run is constant order, in other words it doesn't care how many threads/tasks exist. My guess is that you are exhausting main memory somehow. What do all your threads do? It is hard to see the tulity of 100 threads on a FIRST robot.
HTH
Fast, cheap or working - pick any two!
Unread 02-17-2012, 07:05 AM
Rookie Year: 2012
.. again, the 100 threads are NOT concurrent. It is spawned during the life time of the operation ...
Unread 02-17-2012, 07:41 AM
no team (Team NI)
I'm not that familiar with the Java VM implementation, but I assume it is stack based, like C and C++. Each thread is given its own stack along with other allocations for managing the thread resources. On some OSes that is not too big initially, but they have lots of VM room to grow into. On other OSes, they preallocate lots of stack for each thread. If your stack was 1MByte, then you would run the VM out of memory way before 100.
LabVIEW works around this by having a thread pool and generating its code to not be stack based, but be frame based. That allows it to have hundreds of parallel tasks without having hundreds of threads. But if your OS can handle hundreds of threads, you change a config and tell it to use that many. By default, it has four per processor per priority which are allocated as priorities are added.
On the DS, flip to the new Charts page and run your program. On the far right side are three numbers for free disk, RAM, and largest RAM. If the RAM is constantly dropping, you are hoarding or leaking memory. If the crash takes place about the time your RAM gets low, and especially when the Largest Block gets too small, then that explains it, right?
Greg McKaskle
Unread 02-17-2012, 07:50 AM
Rookie Year: 2012
Then kill the old threads!
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
