Go to Post Every event that starts with "a little bit of fun" has the potential to end in disaster. Please think about all possible outcomes before you do anything stupid. - sanddrag [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Caroll Turpin
ADVERTISEMENT
Unread 02-17-2012, 03:07 PM
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
Weird Problem
Hi, we are encountering a very strange problem..(Again)
Yesterday our code was working fine, but today in the morning when we added in our compresor code EVERYTHING STOPPED WORKING!, we get communication we can deploy our labview code successfully we didnt change anything at all (software/hardware). Everything as in: the Launcher, ball grabber, all autonomous modes, everything!::S
We get the following errors in Diagnotics panel:
FPGA_DIOReadPWMValue.vi>> BuildDashBoard Data.vi >> Robot Main.vi
<Time> 14:58: 50 02/12/2012
FRC: The <b> Digital MOdual </b> is invalid or not found. Make sure to set <b> Digital Modual </b> to either <b>Digital Modual 1 </b> or <b> Digital Modual 2 </b> and ensure the modual is plugged into the spot you specified.
Please take a look at our code
Please and Thank-You
ID:	11955  Click image for larger version
"A team back in training !"
Unread 02-17-2012, 04:54 PM
bstites82 bstites82 is offline
AKA: Blake Stites
FRC #2164 (multiple)
bstites82 is an unknown quantity at this point
Re: Weird Problem
if your compressor loop is in teleop then the loop never exits and hangs up robot main. I would suggest simply using the compressor pallet tools provided to create code like http://www.chiefdelphi.com/forums/sh...d.php?t=102830
Unread 02-17-2012, 07:13 PM
dotbran dotbran is offline
AKA: Brandon Olsen
FRC #3219 (TREAD)
Rookie Year: 2010
dotbran can only hope to improve
Send a message via Skype™ to dotbran
Re: Weird Problem
What the?
Why don't you just use the provided Compressor VIs?
Unread 02-17-2012, 08:33 PM
no team (Team NI)
Re: Weird Problem
You may want to modify the Build Dashboard VI to use the correct slot. There was an issue in the template where the slot is the wrong integer. I think you delete the +1 node.
Greg McKaskle
Unread 02-18-2012, 01:31 PM
FRC #1514 (Vikings)
Re: Weird Problem
Hi, we fixed the problem by doing that but as soon as we did that we got this error:
ERROR <code> 1097 occurred at Call Library Function Node in FPGA_SystemOpen.vi -> FPGA_SystemAsync VI Agent.vi
Edit: When we press run we also get " Teleop is not in memory. :" But its there! :S This also made our autonomous stop working :S Also It counts till Teleop Instance(6) or so. :S Why?
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
