Go to Post Success is inspiring high schoolers to get real world experiance through internships with their sponsors. - Pamela [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ADVERTISEMENT
Unread 02-19-2012, 02:13 PM
gabrielc97's Avatar
gabrielc97 gabrielc97 is offline
AKA: Gabriel
FRC #4029 (Spartan Bots)
Rookie Year: 2012
gabrielc97 is an unknown quantity at this point
Send a message via Skype™ to gabrielc97
Exclamation how to slow the speed of a window/gear motor
We want to slow the speed of one of our window/gear motors because it is too fast. we are using the motor to move a stick to bring down the bridge. we are also using a Victor as a control or possibly a Jaguar. we need help!!
Gabriel
Unread 02-19-2012, 02:22 PM
Andrew Lawrence's Avatar
Andrew Lawrence Andrew Lawrence is offline
Learning something new every day
AKA: Andrew Lawrence
FRC #0256 (Robo Rams)
Team Role: Tactician
Rookie Year: 2011
Andrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond repute
Send a message via Skype™ to Andrew Lawrence
Re: how to slow the speed of a window/gear motor
One possible thing to do is to gear it down by attaching a small gear to the output shaft of the motor, and a larger gear to the shaft of the bridge tipper. This will not only slow it down, but give you more torque to push down the bridge with. This is your best option.
If not, use software to use your jaguar/victor to control the speed. You will get the decrease of speed, however you won't get the increase of torque, something I highly suggest you try to do.
If you have more questions, feel free to PM me.
NEW website? www.Team256.org
Pirate programe's Avatar
Pirate programe Pirate programe is offline
FRC #0354
Pirate programe is an unknown quantity at this point
Multiply the value you're inputting to the Set Output VI by a number less than 1.
EDIT: or you could do what he said, that sounds better
Unread 02-19-2012, 02:37 PM
gabrielc97's Avatar
AKA: Gabriel
Rookie Year: 2012
I cant really do anything on the physical robot, it is a direct drive motor.
Gabriel
Unread 02-19-2012, 02:42 PM
Rookie Year: 2011
If your team won't allow any more changes, change the speed via software through your jags/victors. IF you can change your robot, separate your motor from your bridge manipulator a bit, add a small gear/sprocket on the output shaft of the motor, a large one on the bridge manipulator and then add chain if necessary. If you need help with this, I'd be more than happy to provide examples on our robot.
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
