Go to Post Please review the rules for posting. - meaubry [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ADVERTISEMENT
Unread 02-21-2012, 01:58 PM
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Team Role: Coach
Dale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud of
Resetting the pressure switch
Our pressure switch is currently cutting off at 110lbs so we wanted to reset it to 120lbs. I thought we could just adjust the Allen screw on the side but it doesn't seem to have any effect. Is there something we're missing or are these permanently set at the factory and perhaps our gauge is at fault? Is there some pressuring sequence involved in setting them?
2013 Chairman's (Oregon); 2013 Finalist (OKC); 2012 Winner (OKC); 2012 Chairman's (OKC); 2012 Woody Flowers (Oregon); 2012 Imagery (Oregon); 2011 Volunteer of the Year (Oregon); 2011 Finalist & Captain (San Diego); 2011 Innovation in Control (San Diego); 2010 & 2007 Chairman's (Oregon); 2010 Regional Champions (Colorado); 2010 Innovation in Control (Colorado); 2009 & 2008 Engineering Inspiration (Oregon); 2008 Regional Champions (Oregon); 2007 Regional Finalist (Oregon); 2005 Rookie Inspiration (PNW)
Unread 02-21-2012, 02:35 PM
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #1729 (Plan B)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Re: Resetting the pressure switch
Pressure switches are typically set at the factory and cannot be set to a different value. Most of them are a diaphram, spring, and plunger setup.
Most likely you have loosened something on the switch and made it illegal for FIRST.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 02-21-2012, 02:37 PM
Unsung FIRST Hero
Broadcast Eng/Lead Robot Inspector
AKA: Big Al
FRC #0111 (WildStang)
Rookie Year: 1996
Dale,
These devices are fairly imprecise so 110 psi is possible. There is no adjustment to my knowledge.
Al
WB9UVJ
www.wildstang.org
________________________
Season Eighteen, what a spectacular year! It's has been a bumpy ride. All is better now, new parts are working fine. Champs were spectacular!
Unread 02-21-2012, 02:45 PM
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is offline
Better machine in 2014!
FRC #0122 (NASA Knights)
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
According to the cutsheet for the Nason SM-2B-115R/443 pressure switch, the switch's setpoint tolerance is +/- 5%.
Since the setpoint for this switch is nominally 115 psi (and since 5% of 115 psi is 5.75 psi), a setpoint of 110 psi is in-spec. Sorry!
Unread 02-21-2012, 05:09 PM
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
Team Role: Coach
The weird thing is we've swapped in three switches now and they all read 110. We'll try the gauge next.
Unread 02-21-2012, 06:29 PM
Clifford Clifford is offline
AKA: Clifford Harrison
FRC #2658
Clifford is an unknown quantity at this point
Send a message via Skype™ to Clifford
We've run into this problem before as well. We just went along with that switch, but made space for another accumulator to make up the volume difference. One of our regional inspectors said this was the right choice, since modifying the switch in any way could make it illegal for FRC. I would mark the one you modified and set it aside until you can get an answer from FIRST about whether it can still be used.
Clifford Harrison, Alumni & Mentor
FRC Teams 2658 & 3749
FTC Team 5135
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
