Go to Post It would be interesting to be able to take robots from multiple years and invent new games they can play together (Calvin Ball). - Mark McLeod [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ITT Tech
ADVERTISEMENT
Unread 02-25-2012, 10:36 AM
mickey mickey is offline
FRC #3843
mickey is an unknown quantity at this point
Partial code deployment problem
Im trying to deploy stand-alone labview code to the cRIO. I compile and start deploying the code, but then, partway through the deployment, the robot almost always gives me an error that I cannot deploy target settings and stops. I reboot the cRIO, go to the Driver Station, and it says that there is communications with the robot, and there is code. But the diagnostics tab error messagees give me weird errors such as I have my solenoid module in the wrong spot (it is in slot 7, isnt that where it is supposed to be?) and my code then doesn't work at all (despite the fact I can enter teleop mode).
Unread 02-25-2012, 06:55 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Send a message via AIM to Alan Anderson
Re: Partial code deployment problem
The module positions have been changed this year to accommodate the 4-slot cRIO.
Slot 1: first Analog
Slot 2: first Digital
Slot 3: first Solenoid (optional)
Slot 4: empty on an 8-slot cRIO, any second module (optional) on a 4-slot cRIO
Slot 5: second Analog (optional)
Slot 6: second Digital (optional)
Slot 7: second Solenoid (optional)
Slot 8: empty
Unread 02-25-2012, 07:39 PM
FRC #3843
so slot 7 is for the second one! I switched the cards to the right spot, but the code still didn't deploy. I reformatted the controller and I could deploy code once. When I use the run style of deployment, it seems to refresh the system different than that of stand-alone deployment so that I can redeploy code iff I use run deployment. I suppose I will just deploy stand-alone deployment once and reformat the controller each time I want to re-deploy any code.
Unread 02-25-2012, 09:59 PM
Software Architect
Check your CPU usage on the Driver Station's Charts tab. It sounds like your program might be using up all the processor time and not give the framework a chance to recognize that you want to load a new program. To verify that as the problem, turn on the "NO APP" switch and reboot the cRIO, then see if it will let you load code to run at startup. Make sure you turn the switch back off before letting it reboot after reloading.
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
