Go to Post From a mentor perspective we get to see shy, timid high school kids become leaders in there community and that folks is where we really are winning. - techtiger1 [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Team 221 LLC
ADVERTISEMENT
Unread 02-26-2012, 02:54 PM
Robobuff1.0's Avatar
Robobuff1.0 Robobuff1.0 is offline
FRC #1633
Robobuff1.0 is an unknown quantity at this point
Controlling motors using vision processing help
okay this is my first year programming in Labview. I have read everything I can find about vision processing but I cant find anything about using it to control motors. Can someone help us with this. Our team is trying to follow the rectangular targets using the camera and turret so our shooting mechanism is always aimed at the basket even when we are moving. It will be real helpful if you give me a sample code in labview or direct me to a website. And thank you in advance .
FRC: 1633
FTC: 2873
Unread 02-26-2012, 08:31 PM
no team (Team NI)
Re: Controlling motors using vision processing help
The output of the rectangular target processing is between -1 and 1. You should be able to scale this a bit and build a proportional controller pretty easy. If you do nothing else, you can send the value to the motor, or perhaps the negative of the value.
Another important element is to select which target you are aiming at and keep it consistent.
Finally, you may find that the camera is not a very quick sensor. It is great for deciding how much to rotate, not so great to close a control loop with. You may find that using a pot or encoder may be even better way to go once you know how much to rotate.
Greg McKaskle
Unread 02-27-2012, 11:52 AM
Wendy Holladay's Avatar
Wendy Holladay Wendy Holladay is offline
FRC #1912 (Team Combustion)
Wendy Holladay has a brilliant futureWendy Holladay has a brilliant futureWendy Holladay has a brilliant futureWendy Holladay has a brilliant futureWendy Holladay has a brilliant futureWendy Holladay has a brilliant futureWendy Holladay has a brilliant futureWendy Holladay has a brilliant futureWendy Holladay has a brilliant futureWendy Holladay has a brilliant futureWendy Holladay has a brilliant future
here is my post to the NI site
early in the season we were able to get the rectangular target processing example to see the target and give a distance from it, when we installed the leds.
We are now are wanting the camera to track the target using the servos to move the camera.
i can't see anywhere in this example where that is implemented. is this another example or it there a way to get track distance and camera tracking from this example??
but i'm now glad i checked CD. so is it true there is no target tracking built into the example? we were considering giving the driver's pots to track the target.
but i do not see where the +-1 output is? can you direct me into the block diagram more closely?
http://www.team1912.com
2013, 2012, 2011, 2010 Regional Chairman's Award at the Bayou Regional
2013 Woodie Flower's Award at the Bayou Regional
2012 Dean's List Winner (Rachel Holladay)
2013, 2012, 2011, 2010 Beta Test Labview/Hardware
2012, 2011 Best Website at the Bayou Regional
2011, 2009, 2006 Gracious Professionalism
2007 Bayou Regional Winner
Unread 02-27-2012, 11:59 AM
i think i found the +-1. is it in computer distance.vi
target center (-1 to 1) gives an x and y?
Unread 02-27-2012, 01:53 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Send a message via AIM to Alan Anderson
The rectangular target processing produces a Target info array. Each element of that array is a bundle containing X,Y coordinates and computed distance of each recognized rectangle.
Unread 02-27-2012, 02:56 PM
got it, we have been using the distance, but not the x, y coordinates,
thank u
Unread 02-28-2012, 07:31 AM
no team (Team NI)
There is a camera servo example that does a search pattern, moves the camera to point at a colored object, and has a small state machine for overshoot and other situations. You may be able to adapt it or to get the general idea from it.
Greg McKaskle
Unread 03-20-2012, 05:50 PM
sjsamphex sjsamphex is offline
AKA: Samir
FRC #1261 (Robolions)
sjsamphex is an unknown quantity at this point
Greg McKaskle
Can you tell us where this example is?
Thanks!
Unread 03-20-2012, 07:57 PM
Software Architect
It's with all the other LabVIEW examples on your programming computer.
When you launch LabVIEW, the "Getting Started" window appears. It has a number of tabs down the left side. One of those tabs is "Support", and it leads to a set of links including "Find FRC Examples..."
I think the specific example Greg is talking about is named "Servo Camera Example.lvproj". It resides in the FRC Robotics > Vision folder.
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
