Go to Post Don't let them fail at the end. - DonRotolo [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Chief Delphi Alumni
ADVERTISEMENT
Unread 02-26-2012, 06:23 PM
Andrew Lawrence's Avatar
Andrew Lawrence Andrew Lawrence is offline
Learning something new every day
AKA: Andrew Lawrence
FRC #0256 (Robo Rams)
Team Role: Tactician
Rookie Year: 2011
Andrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond repute
Send a message via Skype™ to Andrew Lawrence
pic: 256 2012 CAD
Unread 02-26-2012, 06:24 PM
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Re: pic: 256 2012 CAD
There's no such thing as too much rendering... It looks good - great job.
Unread 02-26-2012, 06:47 PM
O'Sancheski's Avatar
O'Sancheski O'Sancheski is offline
The Tank Has Arrived
AKA: Joe Sanchez
FRC #0229 (Division By Zero)
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
How much does it weigh and what is the thickness on the extrusion?
2012-20XX: Division By Zero 229/Integration By Parts 4124
2011-2012: Aces High 176
2008-2011: Team Paragon 571
Clarkson University: Class of 2016
Last edited by O'Sancheski : 02-26-2012 at 07:02 PM. Reason: I really need to learn how to spell.
Unread 02-26-2012, 06:50 PM
Rookie Year: 2011
Originally Posted by O'Sancheski View Post
How much does it weight? What is the thickness on the extrusion?
Don't quote me, but I think it's 3/4 inch. The old one weighed 120, but with this new one it will weigh a lot less. The base without the top frame is about 13.5 pounds, and the top frame is about 12 pounds. This is still without any motors, wheels, etc. So for the frame, about a little over 25 pounds total.
I just shocked myself at that number.
Things are subject to change with testing.
NEW website? www.Team256.org
Unread 02-26-2012, 06:53 PM
AKA: Joe Sanchez
If that is true I am shocked you guys are under 120lbs. Most teams that I know of either use 1/16" or 1/8" thick extrusion. Solidworks is showing me that a 12in piece of 3/4" 6061 Aluminum weighs 0.88lbs.
Unread 02-26-2012, 06:55 PM
Rookie Year: 2011
Wait. I may be mixing up what an extrusion is. What is your definition of extrusion? Like what part of the robot?
Unread 02-26-2012, 06:58 PM
AKA: Joe Sanchez
Extrusion is the box aluminum on your robot that the chassis and superstructure is made up of. Most teams use 1x1" boxed aluminum that is 1/16" or 1/8" thick.
Unread 02-26-2012, 06:59 PM
Rookie Year: 2011
Oh! Ok! Thanks. I believe it's 1/8th. If I remember correctly, it wasn't too thin.
Unread 02-26-2012, 07:00 PM
AKA: Joe Sanchez
OK, that sounds better. CAD looks very good. Now what you guys need to do is CAD up the electronics. Then it will look amazing.
Unread 02-26-2012, 07:02 PM
Rookie Year: 2011
Thanks! Our CAD team is doing that as we speak, though it may take a while to transition between our old robot and the new one. We're loosing space, and we were tight as it is on the old one.
Unread 02-27-2012, 02:05 AM
JosephC's Avatar
JosephC JosephC is offline
I'm like Greggy now
AKA: Joseph Cupchack
Rookie Year: 2011
JosephC is just really niceJosephC is just really niceJosephC is just really niceJosephC is just really niceJosephC is just really nice
Mount your electronics sideways.
If you think you don't have any room, try having a short widebot with no room in the middle to put stuff. That's all I have the clearance to say
Joseph, you're awesome.
Unread 02-27-2012, 07:57 AM
Rookie Year: 2011
That's how they are on our old robot. Thanks for the advice, though!
Unread 02-28-2012, 07:00 PM
AKA: Stogi
Send a message via AIM to Akash Rastogi
It looks like your intake is a series of rotating paddles? Why do that instead of just rollers or a conveyor system leading to the vertical conveyor?
Interesting shooter design, how have the results with that setup been so far?
My posts do not necessarily reflect the views & opinions of affiliated teams.
['12-'13]: Mentor FRC 2495
['11-'13]: Co-Founder/Mentor FRC 3929
['06-'10]: Student FRC 11- MORT
Unread 02-28-2012, 07:45 PM
Rookie Year: 2011
Our intake is rotating rubber hose. It slows down the balls no matter what speed they come in, and feed them to our elevator/storage system at a constant speed. We decided to use this system because we thought it would make it easiest to pick up from both sides, and it was what was available to us at both sides. It also plays into our strategy in the event one of the balls gets jammed, we can reverse the rollers and spit out the balls without getting rid of the ones in the elevator. Furthermore, we can use that to feed balls to an alliance member if needed. It's a pretty good kicker.
The shooter results have been excellent! Instead of having control over the horizontal angle of the shooter via a turret, we decided to have vertical control by being able to change the shooting angle, and the shooting power, if needed. It executes beautifully, and gives us consistent scores on the middle and top hoops.
  #15   Spotlight this post!
Unread 02-28-2012, 08:23 PM
cj3958's Avatar
cj3958 cj3958 is offline
FRC #3958 (Schrodinger'd Cat)
Team Role: Student
Rookie Year: 2007
cj3958 is an unknown quantity at this point
What did you use to CAD this? It looks wonderful! I hope you do well at your regional(s)!
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
