Go to Post You get to see great matches at the Championship event regardless of a people's choice event. - Yan Wang [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
Genisys
ADVERTISEMENT
Unread 06-23-2002, 10:09 PM
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
? for Joe Johnson
Posted by David Kelly.
Student on team #234, Cyber Blue, from Perry Meridiam H. S. and Rolls-Royce/ NASA Langley.
Posted on 2/14/2000 7:06 PM MST
This is a qustion for Joe Johnson. I am wondering what the 'no-back' rollers in the drill motors are. Can you discribe what they are and what they look like? We are having trouble locating them.
David Kelly
Team 234
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Answer from Joe
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Engineer on team #47, Chief Delphi, from Pontiac Central High School and Delphi Automotive Systems.
Posted on 2/14/2000 8:15 PM MST
In Reply to: ? for Joe Johnson posted by David Kelly on 2/14/2000 7:06 PM MST:
David,
The 'no-back' pins are deep in the bowels of the transmissions.
To get to them you have to remove everything but the output shaft (from the inside, this shaft looks like a bow tie).
The output shaft as I said looks like a bow tie from the inside. the round section of the bow tie has flats on it. When the carrier drives the output shaft, these rollers are kept in the middle of the flats by the drive pins on the carrier (these pins also drive transfer torque to the output shaft by pushing on the wings of the bow ties).
As long as the rollers are kept in the middle of the flats, they do not jam up against the ring that is fixed to the housing. BUT if the output shaft tries to drive the carrier, the rollers get to the edge of the flats and bind the shaft to the housing.
Thus, the carrier can drive the output shaft but the output shaft cannot drive the carrier. This is a very useful thing for hand tightening and loosening drill chucks, but a lousy thing for rolling robots around.
To disable this feature, all you have to do is remove the pins. They are steel cylinders approx. 3 mm in diameter and maybe 5 mm in length.
I hope this helps.
Joe J.
[IMG] code is Off
Where is Joe Johnson? JVN Chit-Chat 6 01-11-2003 08:24 PM
Full list of teams & competitions archiver 2001 14 06-23-2002 11:52 PM
This one is for Joe Johnson archiver 2000 2 06-23-2002 10:32 PM
New Jersey Regional archiver 1999 7 06-23-2002 09:08 PM
Johnson motors Materials Girl Motors 5 02-12-2002 12:56 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
