Go to Post We do have a good time. Mr. Bill - Bill Beatty [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ADVERTISEMENT
Unread 03-17-2012, 12:20 PM
random_hero random_hero is offline
FRC #3297
random_hero is an unknown quantity at this point
How do you wire the DC/DC converter?
We are working with our extra robot for something to do in our down time. We have blown 2 D-Link bridges when powering on our robot.
We are going from the 12V port on the power distribution blue thing, to the dc/dc converter, then from the dc/dc converter to the bridge. As the negative cable on the d-link cable that we cut, we are using the wire with the dashes on it, which i assume was the negative cable. What are we doing wrong? Thanks.
Unread 03-17-2012, 12:24 PM
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: The mentor formerly known as squirrel
FRC #1726 (N.E.R.D.S.)
Re: How do you wire the DC/DC converter?
Probably what you are doing wrong is assuming that the dashes means negative.
Look at the label on the bridge, does it have a little drawing of the power connection and + and - labels?
Unread 03-17-2012, 12:31 PM
Unsung FIRST Hero
Broadcast Eng/Lead Robot Inspector
AKA: Big Al
FRC #0111 (WildStang)
Rookie Year: 1996
Random,
Regardless of whether you think you have done the correct wiring, prudence demands that you get a meter and check that the polarity and voltage at the connector matches the bridge before you plug it in. It is very easy to use a meter to check continuity to the inner and outer terminals of the plug.
Al
WB9UVJ
www.wildstang.org
________________________
Season Eighteen, what a spectacular year! It's has been a bumpy ride. All is better now, new parts are working fine. Champs were spectacular!
Unread 03-17-2012, 12:41 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
This is from page 30 of Getting Started with the 2012 FRC Control System.
As you can see, the center pin (green arrow) is positive and the shield (red arrow) is negative. Use a cheap ohmmeter to figure out which wire is negative.
Unread 03-17-2012, 04:31 PM
cgmv123's Avatar
cgmv123 cgmv123 is offline
Professional Peon
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Team Role: Electrical
Rookie Year: 2011
cgmv123 is a splendid one to beholdcgmv123 is a splendid one to beholdcgmv123 is a splendid one to beholdcgmv123 is a splendid one to beholdcgmv123 is a splendid one to beholdcgmv123 is a splendid one to beholdcgmv123 is a splendid one to behold
My experience has been that the wire with the dashes is center-pin/positive. TEST FIRST! Your mileage may vary.
I don't get it. We followed all the instructions exactly. Why doesn't it work?
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2013 FIRST Championship Curie Division (#breakthecurse)
2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division
2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson), Semi-Finalist (1732/1714)
2011 Wisconsin Regional Innovation in Control Award
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
