Go to Post why do they call them chips if you can't eat them? - Broadside [more]
Go Back   Chief Delphi > Technical > Programming > WindRiver C++
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ProCare Services
ADVERTISEMENT
Unread 03-30-2012, 10:00 AM
cddp14 cddp14 is offline
FRC #1270
cddp14 is an unknown quantity at this point
Flipping the X - axis
Ok. this a simple problem that I know I am just overlooking a small detail. For this years robot we what to be able to push a button to be able to make the back of the robot to become the front and vice versa during TeleOp mode. The only problem is that the x-axis of doesn't adjust when the switch is made. when the robot is reversed and you move the joystick to the left the robot turns to the right and vice versa. Here is my code below:
MyBase->ArcadeDrive(Driver);
if(Driver->GetRawButton(6))// reverse direction of robot
MyBase->SetInvertedMotor(RobotDrive::kRearLeftMotor, true);
MyBase->SetInvertedMotor(RobotDrive::kFrontLeftMotor,true );
MyBase->SetInvertedMotor(RobotDrive::kRearRightMotor, true);
MyBase->SetInvertedMotor(RobotDrive::kFrontRightMotor,tru e);
if(Driver->GetRawButton(7))// normal configuration
MyBase->SetInvertedMotor(RobotDrive::kRearRightMotor, false);
MyBase->SetInvertedMotor(RobotDrive::kFrontRightMotor,fal se);
MyBase->SetInvertedMotor(RobotDrive::kRearLeftMotor, false);
MyBase->SetInvertedMotor(RobotDrive::kFrontLeftMotor,fals e);
How can I get the X- axis to switch with the reversal? Thanks in advance. Also, I am using WindRiver.
Unread 03-30-2012, 10:18 AM
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a brilliant futureFrankJ has a brilliant futureFrankJ has a brilliant futureFrankJ has a brilliant futureFrankJ has a brilliant futureFrankJ has a brilliant futureFrankJ has a brilliant futureFrankJ has a brilliant futureFrankJ has a brilliant futureFrankJ has a brilliant futureFrankJ has a brilliant future
Re: Flipping the X - axis
You need to also switch around your motors.
left side & right side swaps
Left front becomes right rear
left rear becomes right front
ETC
For a simple tank drive might be easier to swap & invert the joy sticks inputs into the motors.
Unread 03-30-2012, 11:59 AM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Originally Posted by cddp14 View Post
Instead of inverting the motors, just try changing the sign of the joystick X and Y values before feeding them into the arcade algorithm
Unread 03-30-2012, 01:17 PM
FRC #1270
I have looked into doing that but I have not had any success. any sample code would be helpful
Unread 03-30-2012, 01:51 PM
Ether's Avatar
Rookie Year: 1969
sample code? not to be flippant, but this is what I meant:
Code:
Y = -Y;
X = -X;
Unread 03-30-2012, 03:07 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Send a message via AIM to Alan Anderson
Code:
Y = -Y;
X = -X;
Maybe you don't realize that the single-argument ArcadeDrive() method he's using doesn't provide anywhere to do this inversion. The sample code he's asking for is how to get around that lack. By the way, it's only the Y axis that needs to be inverted. The originally posted code is already getting the effect of inverting both axes by running all the motors in the other direction.
Try this: (warning -- untested)
Code:
if(Driver->GetRawButton(6)) // reversed direction of robot
    directionInverted = true;
if(Driver->GetRawButton(7)) // normal configuration
    directionInverted = false;
if(directionInverted)
    MyBase->ArcadeDrive(-Driver->GetY(),Driver->GetX(),false);
else
You'll have to declare directionInverted as a static boolean variable, with an initial value of false.
Unread 03-30-2012, 04:23 PM
FRC #1270
Code:
else
This worked!!! Thanks!!!
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
