#166
Re: IRI - Dates, Info and Rule Ideas
I think it would be interesting if you balanced the balls on the bridge instead of the robots. Maybe 4 points per ball on the bridge to make it more desirable than shooting hoops?
#167
I don't think there is any team, except for the catapults, who could possibly pull this feat off...I'm sure some teams could figure a way out with some modification over the summer, but that seems rather difficult in current configurations.
#168
![]() This is a FTC bot that releases a smaller bot to score the magnet ball. Crazy. |
#169
I just had an idea that I think would be very interesting. It would allow a triple balance during qualification matches AND allow a co-op bridge balance.
Here it is: allow alliance bridge balances at any time during the match. If you balance for 3 seconds, the balance is good. The referees would count the balance like a ref during a WWE match (big arm wave: one! two! three! give something like a touchdown signal, and then it's official - the balance is good). Then the teams can then unbalance themselves and continue the match. Balances score just as they would during an eliminations match - 10 for one robot, 20 for two robots, 40 for three robots. The co-op bridge only counts during the end of a match. If the alliance chooses to balance at the end of the match, regular rules apply (i.e. you don't have to balance three seconds before the end of the match). The strategies could be interesting. |
#170
I've been looking around, but can't find where to begin the application process. Has it begun? Or do you need to be invited to apply?
#172
Wetzel |
#173
A possible process to implement something like this:
#174
Triple Balance Co-op is worth 4 co-op points. One robot has to be from the other team.
#175
Triple balance co-op is worth 3 co-op points. Quadruple balance co-op is worth 4 co-op points. (co-op balancing must feature at least one robot from each alliance, of course) |
#176
IRI seeding algorithm:
I was actually a big fan of the 2010 algorithm with a few tweaks applied. I thought it had the highest potential for doing a good sort on teams. Here is how I would do it for the IRI: Winners seeding points: Winner score + Loser score + Constant Loser seeding points: 2xLoser score Tie score: 2xTie Score for all What about the Co-Op bridge? Co-Op is worth 10 pts. for a single balance to both sides. Co-Op is worth 25 points for a balance with 1 red and 1 blue member. I personally think this carries the right balance for teams. The Co-Op gets doubled for both sides of the field. If the other alliance stands you up at the bridge, you can still get substantial points for it. Close matches will have close qualifying scores. High scoring matches will provide high qualifying scores. There is a general dissincentive for reducing your opposing alliances score (this dissincentive is adjustable by moving the value of the Winning constant up or down). This system also eliminates the incentive for 6v0 which was controversial in 2010. I would award the Co-Opertition award to the highest Co-Op score that is not an alliance captain (possibly alliance captain or higher seed than the lowest seeding alliance captian). I also think that this can serve as a future scoring model for future first games if they want to continue with the "Co-Opertition" aspect. It must be mutually beneficial to both sides, it must be more valuable if both sides participate. It must have some value if only 1 side participates (this should reduce hurt feelings of getting stood up to the prom). This style of play would work for many first games. Having a common central goal. As it ties into both teams points, with my ranking system, the common goal is a doubler for both teams. This give it equal precedence for the Loosing side (loosers get 2L), and higher precedence for the higher scoring side (winners get W+L, therefore Co-Op scoring is 2x the value of W only scoring). Co-Op points could be added in real-time to both scores, or Co-Op could be a seperate entity doubled up for each side at the end of the match. For this years game, I would put the "winning constant" around 25 points. This should be a high enough value for teams to go for the win. This is apretty big tear-up to the seeding algorithm this year, but I think it would be oworth trying out at a high caliber event. |
#177
Plus, if FRC games are to appeal to the masses (which would be nice, right?), then both match scoring and QS have to be simple to explain to anybody--which they are right now. I know that wasn't entirely related to IRI, but part of it sort of connected, and this was a chance to say it. |
#178
Here's a simple idea of how to work the co-op bridge. Instead of giving 2 Ranking points for each alliance, it would just double the Hybrid, Bridge, and Teleop points for that match to reflect in the standings
ie a final score of Red 61(18HP+10BP+33TP ), Blue 58(24HP+10BP+24TP) would really show Red 122(36HP+20BP+66TP), Blue 116(48HP+20BP+48TP) for the standings. This way, there is a premium to utilizing the co-op bridge but it doesn't offset the the amounts of Wins and Losses you have. Now the question is what would you do if there would be a situation where a team would only earn 1 coopertition point. |
#179
Eliminate it.
#180
