Go to Post Any metric you want to apply to Pink, they will pass with flying colors. Pun intended. - Lil' Lavery [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Kettering University
ADVERTISEMENT
  #16   Spotlight this post!
Unread 05-07-2012, 07:41 AM
Unsung FIRST Hero
Broadcast Eng/Lead Robot Inspector
AKA: Big Al
FRC #0111 (WildStang)
Rookie Year: 1996
Re: paper: Window Motor Lockups: Causes and Solutions
Larry,
I could see that using a right and left motor with the pins in place could lead to some locking of one or the other of the motors when used with either controller. However, I have also seen a number of teams use this configuration for arms without any reported difficulty. In those cases the teams intended that the anti-back drive keep their arm in place. They seemed happy with the performance.
In talking with John Novak who did some testing with these motors, it really does appear that the very low mass of the pins (I believe they are phenolic) can easily be set in motion by the switching frequency of the Jags when the motor is not actually moving.
Gary, I had not considered the self heating at 15kHz of the PTC as an issue. However, I think you may be right. If any teams can give us some more data on this, it would be appreciated.
I am going to guess that this operation takes about fifteen minutes per motor. Would that sound accurate?
Al
WB9UVJ
www.wildstang.org
________________________
Season Eighteen, what a spectacular year! It's has been a bumpy ride. All is better now, new parts are working fine. Champs were spectacular!
  #17   Spotlight this post!
Unread 05-07-2012, 11:10 AM
ratdude747's Avatar
ratdude747 ratdude747 is offline
AKA: Larry Bolan
ratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant future
Send a message via Skype™ to ratdude747
Originally Posted by Al Skierkiewicz View Post
Larry,
I see. 1747 did have overheat issues as the result of mixing left and right motors on thier 2011 arm joint. They had locking pins in 1 of the two motors (it also happened wit 2 pinned motors). They ultimately resorted to attaching 2 victor fans to each motor to make the arm usable.
Sounds like a reasonable estimate...
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010
2783 Engineers of Tomorrow 2011
How to wire CAN bus on a budget
  #18   Spotlight this post!
Unread 05-09-2012, 01:35 AM
ratdude747's Avatar
AKA: Larry Bolan
I have uploaded an updated version.
Changes:
-Added a time estimate (15 minutes/ motor) and note about saving the old pins as suggested
-converted the JPEG compression to lossless
-Added my new personal Logo to the end.
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
