Go to Post *sigh* Anything else we can do to get this thing to work? - domoarigato [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ProCare Services
ADVERTISEMENT
  #61   Spotlight this post!
Unread 05-11-2012, 11:06 AM
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a jewel in the roughHadi379 is a jewel in the roughHadi379 is a jewel in the roughHadi379 is a jewel in the rough
Re: Why didn't we think of that?
Originally Posted by mwmac View Post
Team 2122 developed a "bump box" that would hold two balls in hybrid mode and was designed to attach to kop frame members of shooter-less alliance partners. Given the importance of hybrid scoring in this year's game we wanted a way to keep two balls off the co-op bridge and feed them into our shooter. Our programmers wrote a hybrid mode in which our robot would shoot two, back up and bump our partner and load and shoot their two balls. Worked well in finals in Spokane and we got to use it twice at Champs.
Spokane: http://www.youtube.com/watch?v=Ofefwcw56Ow
Here is a pic of the bump box mounted on 4082 in Spokane:
http://dl.dropbox.com/u/60133134/DSC_5768.JPG
Wouldn't any team using the "dump box" have to get reinspected or at least re-weighed in order to compete with it?
  #62   Spotlight this post!
Unread 05-11-2012, 11:41 AM
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
Also who accounts for that in the 30lbs, or did you bag them or build them at the competition?
Spectrum 3847 - Blog - Website - Facebook - Twitter
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
  #63   Spotlight this post!
Unread 05-11-2012, 12:31 PM
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
See [R03] in the Manual -- emphasis added
"The Robot weight may not exceed 120 lbs. When determining weight, the basic Robot structure and all elements of all additional Mechanisms that might be used in different configurations of the Robot shall be weighed together."
As I read the rule, a robot that uses the "dump box" in some matches, but not in others, must be under the weight limit when the "dump box" is added to all of the mechanisms used in other matches. Of course a permanent (for that event) change to remove another mechanism and add the "dump box" would be OK, provided the robot passes a re-inspection; however, changing back and forth between the robot's original configuration and the "dump box" configuration would violate the intent of [R03], unless the combined weight of the robot and all mechanisms is less than 120 lb.
Richard
Whirlpool Corporation, Benton Harbor, Michigan
Mentor since 2002 for FRC 931 Perpetual Chaos (St. Louis, Missouri)
since 2003
(Cosmic Religion : With Other Opinions and Aphorisms (1931) by Albert Einstein, p. 97
  #64   Spotlight this post!
Unread 05-11-2012, 07:39 PM
Gray Adams's Avatar
Gray Adams Gray Adams is offline
FRC #0192 (GRT)
Rookie Year: 2011
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Well, given that both teams made sure the user of the box wouldn't be overweight when using it, they more than likely wouldn't have taken anything off to use it in the first place. So the "all configurations" rule doesn't make a difference if they never have to take anything off to use it, and they don't exceed the weight limit when they use it.
  #65   Spotlight this post!
Unread 05-11-2012, 09:13 PM
Bob Steele's Avatar
Bob Steele Bob Steele is offline
The Skunkfather
FRC #1983 (Skunkworks Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
In the search for a team to use the bump box. Weight was a primary consideration. The bump box was designed to fit on a kit bot frame. 4082's robot weighed less than 60 lbs. They were an ideal partner for 2122 (and our team, 1983). They are a great story. 4 students. 1 mentor. It was a privilege working with them on our alliance in Spokane.
Aviation High School TEAM 1983 - Seattle, Washington
LV 07 Rookie AS, WINNER..(w/ 1425/254)...CMP 07 NEW--SEA 08 EI and WINNER (w/ 2046/949)..CMP 08 GAL-- ORE 09 WINNER (w/1318/2635) CMP 09 CUR SEA 10 RCA CMP 10 GAL--SEA CAS 11 - EI, Deans List, WFA Vol of Year--CMP 11 CUR, 6th seed, Deans List Finalist, Creativity award. --OREGON 12 Finalist, SEATTLE 12 Finalist, SPOKANE 12 Deans List, WINNER (w/2122/4082) and RCA-- CMP 12 Newton Semi-- Central Washington 13 WINNER (w/1425/753)--Seattle 13 WINNER (w/948/492) and RCA --Spokane 13 WINNER (w/ 2471/4125)
  #66   Spotlight this post!
Unread 05-12-2012, 02:36 PM
gerberduffy gerberduffy is offline
FRC #0192
gerberduffy is an unknown quantity at this point
For motor testing on prototypes, we have some little 12 volt black and decker drills that we modified with a lead and anderson connecters. They work quite well and are small and portable. Since it is a drill, you can change the polarity easily too by using the direction control.
Ditto on awesome1730. Power drills are probably the quickest way to prototype for us.
  #67   Spotlight this post!
Unread 05-15-2012, 08:43 AM
Michael DiRamio Michael DiRamio is offline
FRC #1114 (Simbotics)
Team Role: Teacher
Michael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond repute
Originally Posted by slijin View Post
What exactly do you mean by one image?
It sounds like they take one image at the start of the match, then use that for reference for the rest of the match, which I have a hard time believing was ever implemented (although if it's 1114...)
We acquire one image when the operator starts aiming with the camera and use this to calculate how far the turret needs to turn. We found this to be more effective and accurate than acquiring multiple images as the turret swung around.
We have posted an overview of what we did this year for our Programming and Controls here.
  #68   Spotlight this post!
Unread 05-15-2012, 08:58 AM
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
Our protocode was essentially this:
Acquire image, calculate center of the square location (in pixels)
Subtract number of pixels from the center of the image, convert to degrees
If degrees <1 go to shooting; else feed degrees to gyro
Rotate robot that number of degrees
Repeat until shooting is initiated -- generally unneeded, every once in a while it would have to repeat the cycle.
It worked GREAT at home, less so on the field. We haven't parsed out why, yet.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
Like Zombies? Like high school satire? Check out my novel, Twice Shy!
  #69   Spotlight this post!
Unread 05-15-2012, 09:28 AM
Team Role: Teacher
We put a lot of work into identifying the proper target on the field by rating each particle based on height, aspect ratio, size, and fill percentage. The five largest particles were scored and the highest ranked was assumed to be the actual target.
We also look at the lowest target, which means less interference from other light sources.
  #70   Spotlight this post!
Unread 05-15-2012, 10:51 AM
who716's Avatar
who716 who716 is offline
FRC #0716
who716 is an unknown quantity at this point
I liked 1114's Ball picker-upper It was an apendage wich allowed the team to pick up balls that are stuck in the corners of the arena.
  #71   Spotlight this post!
Unread 05-16-2012, 08:46 PM
dsherb5261 dsherb5261 is offline
dsherb5261 is an unknown quantity at this point
I personaly like 1319's elevator and brake pads they had at worlds....now not being involved but sourt of a onlooker i thought they had the right idea but got stuck with some rookies and that messed them up
  #72   Spotlight this post!
Unread 07-21-2012, 11:09 AM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
For teams on a tight budget: If you have an old junker Pentium laptop or desktop computer with a serial port, you can easily use that to generate a PWM signal to control a Victor or Jaguar. Details here.
  #73   Spotlight this post!
Unread 07-21-2012, 09:28 PM
Alex2614's Avatar
Alex2614 Alex2614 is offline
Scapegoat Mentor
FRC #2614 (MARS)
Alex2614 is a name known to allAlex2614 is a name known to allAlex2614 is a name known to allAlex2614 is a name known to allAlex2614 is a name known to allAlex2614 is a name known to all
Send a message via AIM to Alex2614
When I got to championships, I was thoroughly impressed with the systems that lowered the bridge and picked up balls at at the same time (i.e. 67 HOT). It seemed to me that an arm that picked up balls and "dropped" them into another hopper would be too unreliable and "flimsy." That is, that balls would fall out easily and it seemed like too much work to have an actuated arm to pick up balls when we could just do it with a roller. This came up in our original design discussions a couple times, and was eventually shot down every time for many of those ver reasons. However, I think that especially 67's system worked incredibly well for them. The fact that they could go to the bridge and pick up balls at the same time very easily proved to be very beneficial to them. It also worked very well on the floor.
Mountaineer Area RoboticS (MARS) Team 2614 Website Facebook Page
We came to be inspired. We stay because we are. We will become the inspiration.
2013 FIRST Championship - Entrepreneurship Award
2013 Smoky Mountains Regional - Engineering Inspiration Award, Entrepreneurship Award, Quarter-Finalists
2013 Pitt Regional - Entrepreneurship Award, Semi-Finalists
2012 IRI - 16th seed
2012 FIRST Championship - Woodie Flowers Award (Congrats Earl Scime!)
2012 Pitt Regional - Champions, Innovation in Controls Award
2012 NC Regional - Chairman's Award, Finalists
2011 FIRST Championship
2011 Pitt Regional - Semi-finalists, Entrepreneurship Award, Woodie Flowers Finalist (Earl Scime)
2011 Palmetto Regional - Engineering Inspiration Award, Semi-finalists
  #74   Spotlight this post!
Unread 07-23-2012, 11:12 AM
nitsua60 nitsua60 is offline
FRC #2785 (Prometheus)
Rookie Year: 1998
nitsua60 will become famous soon enoughnitsua60 will become famous soon enough
(Sorry, I'm not good with team numbers.)
There was a team at both Suffield Shakedown and the CT regional with a tube-and-fan assembly that collected balls over the bumper, shot, and was strong enough to manipulate the bridge in either direction. It was perhaps 4' long, pivoted at about 1/3 of the way along the tube, and mounted on a turret. (Think of a telescope mount.) A beautiful sight to behold.
  #75   Spotlight this post!
Unread 07-23-2012, 11:20 AM
jwfoss jwfoss is offline
simplicity is the key to victory
FRC #0558
jwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond repute
The team you are referring to is the return of team 23 to FRC. Here is a picture of their 2012 robot.
Justin W. Foss /CU 2010 / Parker APBU / EWCP / Mentor & Event Volunteer
[2013-20xx] FRC Team 0558 - Elm City Robo Squad
[2011-2013] FRC Team 2168 - Aluminum Falcons
[2007-2010] FRC Team 0229 - Division By Zero
[2003-2006] FRC Team 0176 - Aces High
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
