Go to Post Success is the gleam in a child's eyes when they catch their first glimpse of your creation and their life is forever changed. - SlamminSammy [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Callahan's Mufflers & Brakes
ADVERTISEMENT
  #16   Spotlight this post!
Unread 05-11-2012, 01:59 AM
Adam.garcia Adam.garcia is offline
Head of Machining
FRC #0004 (Team 4 Element)
Rookie Year: 1997
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
Re: Custom Two Speed Gearbox
Originally Posted by Tristan Lall View Post
I tend to design 2-speed gearboxes with the ability to spin the wheels when pushing against an immovable object in high gear, to account for the fact that shifters don't always work right. Failing to do this means that if you can't shift, you'll stall the motors pushing on things, and possibly damage the motors. (Depending on your confidence in the mechanism, this may be an unnecessary tradeoff.)
Can you please elaborate on how I should go about ensuring that I design the high gear to slip at stall?
Are there formulas/a calculator/white paper that somebody has written describing this phenomenon?
I'm using Blue Nitrile Tread from McMaster. However, I do not know the coefficient of friction.
Thanks
“The object of education is to teach us to love what is beautiful.”
“Never discourage anyone who continually makes progress, no matter how slow.”
  #17   Spotlight this post!
Unread 05-11-2012, 02:23 AM
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
If you're designing the wheel to slip instead of stall, the force the gearbox can exert on the ground through the wheel should exceed the maximum frictional force that the ground exerts on the wheel. The maximum gearbox force is a function of the motors' torque at stall. The maximum frictional force is a function of normal force (itself a function of weight) and frictional coefficient.
If you're designing the gearbox to always shift into low in case of a failure, you should characterize the possible failures and try to deal with them. This isn't easy for shifting mechanisms that don't return to a home position (e.g. servos) during a malfunction, and is also difficult if you can't walk up to the robot to override a malfunctioning valve (which you can't, at least not during a match). Since redundant actuators and control channels aren't really feasible under most circumstances, taking this design approach will invariably lead you to compromise—but that might be good enough.
John V-Neun wrote one, and has updated it over the years. It's very useful. Others have written similar tools (like this and this), but I haven't tried them.
Probably about 1.0 on carpet (an educated guess). See here for a bit more information.
  #18   Spotlight this post!
Unread 05-11-2012, 08:47 AM
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Send a message via Skype™ to sdcantrell56
Any type of roughtop seems to be more like 1.2 to 1.3. I would try to ere on the side of caution rather than pushing things so definitely use the higher coefficient of friction.
2012 Peachtree Regional Champs
2011 North Carolina Regional Champs
2011 Peachtree Regional Champs
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
