Go to Post "Look, it's already weight optimized!" - Samk [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Team 221 LLC
ADVERTISEMENT
Unread 05-10-2012, 02:42 PM
craigboez's Avatar
craigboez craigboez is online now
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Source for Shaft Couplers
Does anyone have a good source for inexpensive shaft couplers? I'm looking to couple a 1/4" od encoder to the end of a 1/4" od shaft for the steering portion of a swerve module. Both shafts will be smooth, no flat spots, so I'm looking for a clamp style (not set screw style) shaft coupling. To allow for some manufacturing tolerances I don't want it to be completely rigid, so I was looking at using a semi-flexible slit type coupling like this.
At $13.50 the SDP/SI plastic version is the cheapest version I could find. Aluminum versions all seem to be $25-30. Any comments on plastic vs aluminum?
Automation direct makes some (here) for $7 but they're setup for 6mm shafts. Does anyone have experience with these - do they work for 1/4" shafts, do they require modifications, etc?
Since we'll be buying several of these I'm trying to find the most economical option that will still be reliable. Any suggestions are greatly appreciated.
Thanks.
Unread 05-10-2012, 02:55 PM
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Send a message via AIM to Madison
Re: Source for Shaft Couplers
While not very pretty, we often couple encoders to shafts using surgical tubing that is zip-tied into place. It works quite well.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Build season blog:
http://teamxbot.blogspot.com/
Unread 05-10-2012, 02:58 PM
Akash Rastogi's Avatar
FF: Flippin' The Greatest
AKA: Stogi
Send a message via AIM to Akash Rastogi
I've never looked at the cost while ordering these at work, but the company we always go to is Ruland.
http://www.ruland.com/index.asp
['12-'13]: Mentor FRC 2495
['11-'13]: Co-Founder/Mentor FRC 3929
['06-'10]: Student FRC 11- MORT
Unread 05-10-2012, 03:08 PM
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
FRC #0020 (The Rocketeers)
Rookie Year: 2010
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
http://www.mcmaster.com/#standard-sh...plings/=hh6zib
There are a variety of shaft couplings here and you can specify which bore sizes you want.
2013 UTC Connecticut Regional Quality Award, Safety Award, and Champions (195 & 95)
2013 WPI Regional Quality Award, Safety Award, and Finalists (2791 & 3182)
2012 Northeast Utilities Connecticut Regional Champions (195 & 181)
2012 BAE Granite State Regional Safety Award
2011 BAE Granite State Regional Finalists (131 & 40)
2010 Newton Division Semifinalists (2757 & 668)
2010 WPI Regional Creativity Award, Coopertition Award, and Champions (228 & 230)
2010 BAE Granite State Regional Excellence in Design Award and Entrepreneurship Award
Unread 05-10-2012, 03:33 PM
Unsung FIRST Hero
JVN JVN is offline
VEX Robotics Engineer
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Rookie Year: 2000
JVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond repute
Thanks.
Do you have access to a 3D printer? I've had good luck in the past with custom 3D printed couplers for applications like these.
-John
Unread 05-10-2012, 03:39 PM
R.C.'s Avatar
R.C. R.C. is online now
Ramping Up for the 2013 Season!
AKA: Owner, WestCoast Products & Design LLC
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Send a message via AIM to R.C.
We've used these on our 2011 and 2012 robot for our arms/turrets.
http://www.mcmaster.com/#9658T3
-RC
Unread 05-10-2012, 04:34 PM
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
Same here.
Unread 05-10-2012, 04:35 PM
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
We use the Automation Direct Couplers that were mentioned on our swerve steering sensor - 1/4" shafts. Just reamed them out. Be careful to not insert the shaft in too far or you will turn them into ridged couplers. A shaft flat can always be filed. Have worked well and the price is nice.
Unread 05-10-2012, 06:06 PM
Unsung FIRST Hero
Broadcast Eng/Lead Robot Inspector
AKA: Big Al
FRC #0111 (WildStang)
Rookie Year: 1996
Small Parts Incorporated, they were an FRC sponsor long ago. Now they are part of AmazonSupply.
Al
WB9UVJ
www.wildstang.org
________________________
Season Eighteen, what a spectacular year! It's has been a bumpy ride. All is better now, new parts are working fine. Champs were spectacular!
Unread 05-10-2012, 07:54 PM
AlexH's Avatar
AlexH AlexH is offline
lol robots
Team Role: Mechanical
Rookie Year: 2010
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
https://www.surpluscenter.com/item.a...ame=powerTrans
two of these would work
Unread 05-10-2012, 08:15 PM
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
we made small flats on the potentiometer shaft and the shaft we were mounting on, and used the set-screw version from McMaster referenced above. They worked very well and are easy to install.
Chris Fultz
Cyber Blue - Team 234
2013! IRI Planning Committee - Co-Lead.
2010 - Woodie Flowers Award - Championship
Unread 05-10-2012, 08:54 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
We do the same. We got the idea from Dan Katanski from team 240.
Unread 05-10-2012, 09:52 PM
ratdude747's Avatar
ratdude747 ratdude747 is offline
AKA: Larry Bolan
ratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant futureratdude747 has a brilliant future
Send a message via Skype™ to ratdude747
In addition, that also is good for dealing with misaligned holes. Trust me, it happens.
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010
2783 Engineers of Tomorrow 2011
How to wire CAN bus on a budget
Unread 05-10-2012, 11:53 PM
Mk.32's Avatar
Mk.32 Mk.32 is offline
Team Leader.
AKA: Mark
FRC #3647 (Millennium Falcons)
Rookie Year: 2011
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Unless you are 254/1114/1538/118/ETC
Team 3647 Code FaceBook Blog
2013 Inland Empire Regional: Semi-Finalist 1323 and 399
2013 SD Regional
2012 BATB: Semifinalists 6399 and 2658
2012 La Fall Classic: Finalist 1538 and 3309
2012 Madtown: Quarter Finalists
2012 SD Regional
2011 BATB: Semifinalists (3647, 3633, 2102)
2011 LA Fall Classic: Finalists (3647,399,980/696)
2011 SD Regional
  #15   Spotlight this post!
Unread 05-11-2012, 07:39 AM
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
Anyone have a picture of how they use the surgical tubing to connect an encoder to a shaft?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
Like Zombies? Like high school satire? Check out my novel, Twice Shy!
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
