Go to Post I don't see why this is an issue. Robots are immune to the N1H1 virus. - JesseK [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Team 221 LLC
ADVERTISEMENT
Unread 05-15-2012, 09:41 AM
DavidVang.2012's Avatar
DavidVang.2012 DavidVang.2012 is offline
TeTsuTo
FRC #2500 (Herobotics)
Rookie Year: 2010
DavidVang.2012 is an unknown quantity at this point
Closed PID loop for Speed Control
We are currently trying to create a closed PID loop that will essentially be able to control the speed output of our drive wheels as we give input through our joysticks.
Is there anyone out there who is willing to share their developed [and working] closed PID loop so that I can get a better picture of what I need to include in the program? A simple closed PID loop program will be sufficient.
Thank you very much.
Unread 05-15-2012, 12:04 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Send a message via AIM to Alan Anderson
Re: Closed PID loop for Speed Control
LabVIEW includes PID functions already. To find them, open the function palette and search for "PID".
Since you want to control speed instead of position, you have two basic options. Either use the output of the PID function to add to or subtract from your motor power instead of using it as the motor power directly, or get an equivalent effect by running the PID function using the I term as if it were the proportional constant.
Unread 05-15-2012, 08:48 PM
Tom Line Tom Line is offline
Autonomouse
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Check out the Velocity PID (2012) located here:
http://www.fightingpi.org/Controls.html
It's in labview, and is commented fairly well and should be self explanatory if you know basic PID theory. Thanks to Jared from team 341 for giving the derivation in 2009 that we used to create this PID to control our shooter this year.
Team 1718 LabView Tutorial
Unread 05-15-2012, 10:15 PM
blackflame2996's Avatar
blackflame2996 blackflame2996 is offline
VP of Programming, Driver
AKA: David Donahue
FRC #2996 (Cougars Gone Wired)
Rookie Year: 2011
blackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to all
Send a message via Skype™ to blackflame2996
Just out of curiosity, why use PID for a user controlled drive system? This seems unnecessary. PID is nice for things like shooters, but why use it with the drive?
2009 Regional Winners
2011 Regional Chairman's Award
2012 Regional Winners
2013 Regional Chairman's Award
Unread 05-15-2012, 10:20 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Autonomous. Computer-assisted bridge balancing. More predictable response to driver commands in the presence of varying battery voltages.
Unread 05-15-2012, 11:08 PM
Autonomouse
Rookie Year: 1999
Traction control (2009).
Maintaining a set field position.
We're not even talking about a swerve drive....
Unread 05-17-2012, 05:11 PM
AKA: David Donahue
Rookie Year: 2011
I see. we'll keep that in mind.
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
