Go to Post Side effect include: Hearing loss, splinters, blisters, extreme sprit, uncontrollable urges to scream "GO MOE", and bright green fashion sense - The Lucas [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Tormach
ADVERTISEMENT
Unread 05-17-2012, 06:34 AM
Programmer3941 Programmer3941 is offline
No Resistance. Absolute Power.
FRC #3941 (Absolute Zero Electricity)
Team Role: Student
Rookie Year: 2012
Programmer3941 is an unknown quantity at this point
Rookie Team needs programming help
I'm part of an ex-rookie team(3941), and all of our programming was done in Labview, by one person who has now graduated. Now we have to figure out what programming language to use.
Hear is our situation
C++: probably not
Labview: I do not know very much labview, but what I did learn from last year seemed fairly easy. There was also a lot of stuff already set up for FIRST. However, I did not really like the graphic format, and the code took forever to download.
Java: I know java, but do not know how to program a robot with it. There seems to be much less stuff already set up for FIRST. I like java, and would use it, but it seems much harder to get started with.
Any help much appreciated!
Team 3941 Absolute Zero Electricity
Engineering Inspiration Award Winner, Chesapeake Regional 2013
Rookie All-Star Award Winner, Chesapeake Regional 2012
http://frc3941.com
Unread 05-17-2012, 07:05 AM
Djur's Avatar
Happy Birthday! Djur Djur is offline
I Java.
AKA: Sam Carlberg
FRC #2084 (Robots by the C)
Djur will become famous soon enough
Re: Rookie Team needs programming help
*snip*
Seeing as you're already familiar with Java, I assume you already have Netbeans. If you don't, just go here to download it.
WPI supplies a good document for getting started with Java. Page 5 tells you how to install the FRC plugins, which allow you to create new FRC-specific projects. You should also check out Brad Miller's video tutorials on YouTube to help learn the basics of Java-based robot programming.
Hope this helps!
"Wow." - Dean Kamen on 2084's Rebound Rumble 'bot.
Finalists in the 2012 Boston Regional with 125 and 78
LiveWindow, RobotBuilder, and WPILibJ developer.
Unread 05-17-2012, 08:09 AM
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
If you'd like to stick with LabView, you may be able to find a mentor from the local LabView Users group; there is one that meets about an hour away in Columbia that may draw from Aberdeen. Here are their websites:
https://decibel.ni.com/content/groups/nicommidatlantic
http://www.minkhollowsystems.com/WALUG.html
All of our software mentors are members of the local Users group and found out about FIRST and our team through it. Maybe you could give a presentation at one of their meetings to promote FIRST and see if you can recruit someone.
Close enough to taste it, too far to reach it
Unread 05-17-2012, 05:50 PM
blackflame2996's Avatar
blackflame2996 blackflame2996 is offline
VP of Programming, Driver
AKA: David Donahue
FRC #2996 (Cougars Gone Wired)
Rookie Year: 2011
blackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to all
Send a message via Skype™ to blackflame2996
we have found LabVIEW to be ideal for our team, as a result of it enabling the members of our team who are interested in programming, but have no C or Java background, to do so. If you and the other programmers are comfortable with Java, the WPI library is easy to pick up, so I would recommend going Java. Otherwise, if the bulk of the programmers on your team are not comfortable with text-base, go LabVIEW.
2009 Regional Winners
2011 Regional Chairman's Award
2012 Regional Winners
2013 Regional Chairman's Award
Unread 05-17-2012, 06:12 PM
LeelandS's Avatar
LeelandS LeelandS is offline
Taken to school every day by CD
AKA: Leeland
FRC #1405 (Finney Falcons)
Team Role: Tactician
LeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond repute
As a student who was on a team who cycled through 3 different programming languages over a few seasons, I may be able to offer a little insight, especially on switching to Java.
First of all, if you're comfortable with Java, use Java. If you feel that, after evaluating Java for FRC purposes, then you have two options:
-Learn C++. It's somewhat similar to Java, albeit some key differences. More or less, if you can program in Java, learning C++ will be less of a challenge. That's from personal experience. I haven't looked, but I've also been told several times (by mentors trying to get us back to C++) that C++ is also much more supported for FRC. So that's an option.
-Look at your previous year's Labview code. Try to learn it, make sense of it, etc. I don't know how documentation in Labview works, but if it is properly documented, that should be quite a learning experience. If it's not properly documented... that could be quite a task.
Now, if you decide you'd like to stick with Java, there are another few things I can suggest:
-Look for teams who have posted Java code online. If nothing else, you should be able to better understand how Java works in terms of FRC.
-Practice by converting your old Labview code to Java. 1126 did that in 2010 I believe, converting our 09' bot (Labview) to Java. That has long since passed, with the dismantling of the 09' bot, but it could be a great experience for you and anyone you do it with.
-Make sure you know the basics of Java in general FIRST. That'll make things go over a little smoothly. That's just a general rule, though.
I hope these help. The most basic thing I can suggest is think your decision through. Look over all the basis you have, consider all your option.
My heart will forever lie with SparX
FIRST Addict: 2004 - Present
Unread 05-17-2012, 07:12 PM
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
One of the first documents I send to students interested in Java for FRC was posted in this thread.
http://www.chiefdelphi.com/forums/showthread.php?t=85836&highlight=new+programming+m anual
v9 is the latest I think, posted on post #24 of that thread.
It's a bit out dated now, but is still a very nice introduction to a lot of aspects of programming FRC robots in Java.
Spectrum 3847 - Blog - Website - Facebook - Twitter
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 05-17-2012, 10:39 PM
TheNightviz's Avatar
TheNightviz TheNightviz is offline
Driving it like I stole it.
AKA: Parker
FRC #3255 (Super NURDs)
Rookie Year: 2012
TheNightviz is an unknown quantity at this point
If your looking for some examples for a Java based bot here is a link to my teams code for this year!
http://code.google.com/p/first-robot...2Fnurdrobotics
Also we are completely rewriting the code in a different (and much simpler) form which we will soon be releasing on the same link provided. Hope this helps and if you have anymore questions feel free to ask!
Unread 05-18-2012, 01:19 PM
gixxy's Avatar
gixxy gixxy is offline
Head:Java, Arduino, Web, Electrical
AKA: Gus Michel
FRC #3946 (Tiger Robotics)
Rookie Year: 2012
gixxy is an unknown quantity at this point
Send a message via Skype™ to gixxy
Based on what you say, Java is probably the best bet. It will be easier for you to code in and probably easier to get others who can handle it into the language as well. (because you know it already, not because it is just easy, although as far as programming languages go, Java is fairly easy)
Its not complicated at all really, its a Java library just like any other.
Here is our Java code from this year(we were rookies when we wrote it, and only I had any experience in Programming [in PHP]): https://github.com/frc3946/ReboundRumble
Programmer - A creature known for converting Caffeine into Code.
Using Java, C, C++, Python, PHP, BASH, and PBASIC I will reject your reality and Code my own.
FRC 3946 Github
Unread 06-01-2012, 07:59 AM
Team Role: Student
Rookie Year: 2012
Thumbs up Re: Rookie Team needs programming help
This was so helpful, your code is so well documented!
http://frc3941.com
Unread 06-24-2012, 10:22 PM
Gregor's Avatar
Gregor Gregor is online now
Looking for a Team
AKA: Gregor Browning
Team Role: Student
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
reported
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2010 Glen Ames Robotics-Student
FLL 2011-xxxx Glen Ames Robotics-Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Driver
Add me on Facebook
<Since 2011
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
