Go to Post There's more than one way to skin a cat. - Al Skierkiewicz [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ITT Tech
ADVERTISEMENT
Unread 06-05-2012, 03:50 PM
joelg236's Avatar
joelg236 joelg236 is offline
- Lead Programmer -
AKA: Joel
FRC #4334 (Alberta Tech Alliance)
Rookie Year: 2012
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Preferences check if the element exists
Hi CD,
I am working on some code to interface with the preferences class that is accessible in SmartDashboard. Unfortunately, I don't know how to figure this part out.
Code:
     * Gets the integer from preferences.
     * @param ID ID of the integer
     * @param backupValue The value to return in preferences does not contain it
     * @param replace If the backup value has to be used, should the value be inserted?
     * @return Returns the integer saved in preferences
    public static int getInt(String ID, int backupValue, boolean replace) {
        int backup = backupValue;
        try {
            if(m_data.elementAt(m_names.indexOf(ID)) != null) {
                backup = ((Integer)m_data.elementAt(m_names.indexOf(ID))).intValue();
// Checks to see if my code has the element stored^^^
        catch(ClassCastException ex) {}
        catch(ArrayIndexOutOfBoundsException ex) {}
//These exceptions are okay to catch because my code might not store it already
        if (Preferences.getInstance().getInt(ID, backup) == backup && replace) {
// This is where I have a problem. I can check if its the same as backup -
//which will happen when it goes to the backup value yes, which does its
//purpose. But for optimization, everytime the field is actually the backup
//(No matter if it exists or not), it will save the value. That takes up
//bandwidth and slows the code down. NOT what I want to do, especially
//because a lot of the values will be the same as backup.
            Preferences.getInstance().putInt(ID, backup);
            save();
        return Preferences.getInstance().getInt(ID, backup);
I wrote the problem in the code in comments, just in case you didn't notice it.
Win with pride.
Team 4334
ATAlibj
Github
2013 Code
Unread 07-05-2012, 09:18 PM
joelg236's Avatar
- Lead Programmer -
AKA: Joel
Rookie Year: 2012
Re: Preferences check if the element exists
I found the solution to this problem, so I'll post the answer for reference.
Code:
    public static String getSetting(String name) throws NoSettingFound {
        if(Preferences.getInstance().containsKey(name)) {
            return Preferences.getInstance().getString(name, null);
        }else {
            throw new Errs.NoSettingFound(name);
Basically, there is a method meant just for this problem.
Win with pride.
Team 4334
ATAlibj
Github
2013 Code
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
