Go to Post It shouldn’t be about whether or not you think it’s easy or not, it’s about whether or not you think the effect of the change would be a positive step for our country. - Bill Gold [more]
Go Back   Chief Delphi > Old Forum Archives > 2001
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Perry Street Auto
ADVERTISEMENT
Unread 06-23-2002, 10:58 PM
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
circuit breakers....
Posted by Anton Abaya at 2/1/2001 12:08 AM EST
Coach on team #419, Rambots, from UMass Boston / BC High and NONE AT THE MOMENT! .
when the circuit breakers trip...do i assume that the speed controllers wont get power either? (meaning it doesnt run or have any lights at all?)
i ask this because our motor stopped working and i had to open the case up to figure out if it was the wiring. so i never really figured out what the heck was wrong... heh...
-anton
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Re: circuit breakers....HOT!
Posted by Steven Tine at 2/1/2001 1:32 AM EST
Engineer on team #111, Wildstang, from Wheeling & Rolling Meadows H.S. and Motorola.
In Reply to: circuit breakers....
Posted by Anton Abaya on 2/1/2001 12:08 AM EST:
From past experience, the 30A circuit breakers do not straight trip when there is a short across the output, instead they flicker on and off rapidly. So, the breaker will get hot enough to trip (since they are thermally triggered) for about a second, then during that second it cools enough to return to the regular connected state. Then it repeats the above steps...getting hot then tripping for about a second over and over again. The best way to tell if your circuit breaker is tripping is to quickly feel its temperature. It will be quite hot if the breaker is your problem. You will also hear a slight clicking sound as it turns on and off.
Basically, it does not sound like the circuit breaker was your problem.
Hope that helps!
#0047 (ChiefDelphi)
Posted by Al Skierkiewicz at 2/1/2001 1:44 PM EST
Engineer on team #111, Wildstang, from Wheeling High & Rolling Meadows High and Motorola.
: when the circuit breakers trip...do i assume that the speed controllers wont get power either? (meaning it doesnt run or have any lights at all?)
If you have wired the circuit breakers in series with the speed controllers as required by electrical rules then the answer is yes, no power will be supplied to the controllers. However the normal trip mode is as Steve described.(See Steve's post) A total death (no lights at speed controller) may be due to a bad crimp, bad circuit breaker, shorted motor or bad speed controller. Check the first three before swapping out the speed controller.
[IMG] code is Off
speed controllers & circuit breakers deuceswild Electrical 2 01-15-2003 01:46 PM
Circuit breakers archiver 2000 8 06-23-2002 10:30 PM
Circuit Breakers: Tripping Al Skierkiewicz Electrical 7 04-10-2002 11:40 AM
Circuit Breakers ark_1230 Electrical 28 04-09-2002 10:16 PM
Shocking News about Circuit Breakers Joe Johnson Technical Discussion 0 03-19-2002 11:08 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
