Go to Post I'm sure you can come up with something, with a bit of warped thought! ... and if not, warped thinking is what your team's Engineers are for! :) - kmcclary [more]
Go Back   Chief Delphi > Old Forum Archives > 2001
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Delphi
ADVERTISEMENT
Unread 06-23-2002, 11:56 PM
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Compacting the arms...
Posted by Dan Richards at 2/15/2001 8:14 PM EST
Student on team #550, WCTS Robotics, from Warren County Vo-Tech and WCTS.
Hey. What's the smallest diameter pipe or rod that will not bend (much) with 20 pounds on it? Anyone know? Also, I have a Victor that decided to short itself out and only go in reverse now. Anybody want it or know a use for it?
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Re: Compacting the arms...
Posted by Tim Gates at 2/15/2001 10:57 PM EST
Engineer on team #288, RoboDawgs, from Grandville High School and X-Rite/Delphi.
In Reply to: Compacting the arms...
Posted by Dan Richards on 2/15/2001 8:14 PM EST:
That is a very broad question. When 20 pounds mass is in motion and you try to stop it, your going to have more than 20 pounds force exerted on the moment and at what distance from the pivot or fulcrum. Without more info about your application, I would suggest you try schedule 40 PVC, it's surprisingly strong, light and quite resilient. Also, an I-beam cross section is very efficient if the force is applied vertical and without any lateral stresses.
Tim Gates
Tim Gates
#0047 (ChiefDelphi)
Posted by Matt Leese at 2/15/2001 11:01 PM EST
Other on team #73, Tigerbolt, from Edison Technical HS and Alstom & Fiber Technologies & RIT.
In Reply to: Re: Compacting the arms...
Posted by Tim Gates on 2/15/2001 10:57 PM EST:
Well, Schedule 40 PVC is strong, sometimes. It's much better at taking tension or compression forces than it is in taking lateral forces. So if you're trying to make an arm out of it with some sort of weight attached, it'd be much more likely to break. At this point I think your best bet is to just try different materials and see what works. One thing that you might try is electrical conduit but it does tend to be rather heavy (it's steel usually).
Matt
#0047 (ChiefDelphi)
Posted by Joe Ross at 2/15/2001 11:24 PM EST
Engineer on team #330, Beach Bot, from Hope Chapel Academy and NASA/JPL , J&F Machine, and Raytheon.
: Hey. What's the smallest diameter pipe or rod that will not bend (much) with 20 pounds on it? Anyone know? Also, I have a Victor that decided to short itself out and only go in reverse now. Anybody want it or know a use for it?
Was the victor connected improperly, or did it fail in normal use? If it failed in normal use, innovation first should replace it for you.
[IMG] code is Off
What do you think of team 61 robot Walter_Jr Robot Showcase 69 04-01-2003 10:41 AM
pic: arms out CD47-Bot Robot Showcase 23 03-05-2003 02:49 PM
Arms mikeL 177 General Forum 2 02-19-2003 10:15 AM
We're really not that mean. archiver 1999 59 06-23-2002 09:49 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
