Go to Post I think with so many facets of FIRST, success comes from learning the true meaning of teamwork through working towards a common goal. - Kristina [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Kettering University
ADVERTISEMENT
Unread 11-07-2002, 10:19 AM
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy is an unknown quantity at this point
Pnuematic programming
Is there any resource out there for pnuematics code? I don't quite understand how the pressure switches work, but the pnuematics manual doesn't mention any pinouts or where to wire the switches.
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
Unread 11-07-2002, 11:54 AM
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Rookie Year: 1999
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
Do a quick search of the forums, it will bring up many threads.
The pressure switch is a digital input that should be shown how to wire a digital input in the manual for the control system, you can pick the input. We had no pnuematics last year but I think it was adjustable for the pressure that will trip it. Then you can Turn on/off the compressor based on the switch or two switches (one for high, one for low) I think there are also a few white papers on Compressor programming
Check this white paper on the sixth page of white papers for an example
Description:
Pneumatic Wiring and Programming
originally submitted: 01.18.2001
by Dan Grostick
Unread 11-07-2002, 12:36 PM
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
http://www.chiefdelphi.com/forums/sh...t=pneumati cs
The pressure switches are like any standard digital input. There's no + or -, no specific way to wire it or hook the tubing up for the pneumatics.
When it needs to be filled, the pressure switch will be closed, it will show up as a 1 in programming (current).
When it is filled, the pressure switch is open, which is a 0 in programming (no current).
The rubber stopper on top is removable. Underneath it is a screw that can be adjusted. Tightening (clockwise) will raise the tripping pressure. Loosening the screw (counter-clockwise) will lower the pressure.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 11-07-2002, 01:13 PM
f22flyboy's Avatar
cool thanks
Team 540 Forums
Unread 11-11-2002, 01:37 PM
f22flyboy's Avatar
I realized that one page didn't print when I printed out the control manual - the page with ports and pin-outs for switches. Thanks for your help anyway
Team 540 Forums
Programming Compatition Angela06 Programming 30 04-08-2005 10:12 PM
Communications via the Programming Port Larry Barello Technical Discussion 9 06-10-2003 10:33 PM
Pneumatics electrical wiring and programming archiver 2001 1 06-23-2002 10:10 PM
Error found in programming for the pump and pressure switch sjharobotics Programming 4 02-06-2002 04:46 PM
pbasic programming punarhero Programming 4 01-21-2002 10:32 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
