Go to Post With a little time and practice, I think that most people would find that there is no magic involved in programming. - Dave Scheck [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Kettering University
ADVERTISEMENT
Unread 11-13-2002, 10:32 AM
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
SPIKE relays
Has any one else noticed that the Innovation FIRST website only shows the RED Spike relays?
This changes the wiring diagram compared to the spikes we received the last two years. The solenoids will now always be 'HOT' (12v+).
The BLUE spikes are still available from IFI.
Unread 11-13-2002, 11:27 AM
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy is an unknown quantity at this point
??? The only difference is a built in 10% dead zone, which is best for FIRST because 10% won't move a bot
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
Unread 11-13-2002, 12:22 PM
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Rookie Year: 1999
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
The dead zone apply's to the Victors, I think it was the red 884 was for arm positioning without the Dead zone
The spike wiring for red and blue should be in the manual, here it is:
The “red” Relay Modules connect the M+ and M- outputs to +12 Vdc when in the off state. The “blue” Relay Modules connect the M+ and M- outputs to Ground when in the off state. On both
types, M+ is connected to +12 Vdc and M- is connected to Ground when the Relay Module is in “Forward” mode, and vice versa for “Reverse” mode. Normally, the Relay Modules are connected
across both leads of a DC motor, which means that both types provide equivalent bi-directional motor control. However, it may be desirable to utilize the M+ and M- outputs to independently
control simple on-off devices or motors which only need to run in a single direction, in order to reduce the number of Relay Modules needed. If independent control of two devices is to be used, the wiring must be based on the type of Relay Module.
The spike will have 12V at both terminals with no 'potential' between them thus the the solenoit will not shift
Spike RED Pinout Venkatesh Electrical 3 03-31-2003 08:42 PM
spike for pressure switch? Rob Colatutto Rules/Strategy 4 02-23-2003 02:42 PM
spike great_one411 Electrical 2 02-06-2003 08:10 AM
Spike Relay Input nwagers Electrical 3 07-16-2002 09:23 PM
How do you control relays BinaryBob0001 Technical Discussion 2 01-21-2002 07:42 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
