Go to Post Super Regional? I don't know...if you combine NJ and Philly the universe might tear a hole in itself...and we wouldn't want that now would we? Mwahaha. - George A. [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ADVERTISEMENT
Unread 01-04-2003, 04:49 PM
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
Rookie Year: 1998
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Are specs available on the new motors/mounts?
I don't have the rulebook with me here so I apologize if this is in an appendix.
The FIRST site does not have the torque/speed specs for the new motors. Are tey available somewhere?
Also, are drawings for the supplied motor mounts available?
Matt B.
Unread 01-05-2003, 01:06 AM
AdamT's Avatar
AdamT AdamT is offline
#0401
Rookie Year: 2000
AdamT is on a distinguished road
At the current time, no. In fact the appendix is empty and will only be added to by team updates.
~Adam
Unread 01-06-2003, 08:26 AM
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics
FRC #0217 (ThunderChickens)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
Working On It.
I have contacted the motor manufacturer's for the following motors:
1. Drill Motor
2. Atwood Chiaphua
3. F-P motor
4. Window Motor
I suspect that the globe motor is the same as last year (look in Dr. Joes Motor Spreadsheet in the White Papers section).
I also suspect that the only difference in the Atwood is the shaft, but will confirm. The Atwood from last year has the following performance specs:
1. Stall Torque = 2.2 N-m
2. Free Speed = 5500 RPM
3. Stall Amps = 107
4. Free Amps = 2.3
The Atwood Shaft diameter is: ~7.92mm. This is probably an 8mm shaft undersized by 0.05 to 0.10 mm. The keyway is made for a standard 2mm square key (included in kit).
I want to warn you about the F-P motor!!! The specs in the FIRST manual are for lasts year's Johnson Electric Motor, not the ones that I pulled out of the kit. Our F-P motor only had 19 teeth, not 21 and was not the same motor as last year. I have already contacted the appropriate people at the motor manufacturer and should have the info by the end of the day tomorrow.
As soon as I confirm, I will post all specs and drawings that I receive.
drill motor specs Caitlyn691 Motors 34 01-17-2003 12:33 PM
Q&A Discuss: Are specs available on the new motors/mounts? CD47-Bot Extra Discussion 3 01-15-2003 06:39 PM
motor specs? Gary Dillard Motors 0 01-04-2003 04:54 PM
On-board chip spec's archiver 2000 4 06-23-2002 08:55 PM
Motor specs kmcclary Chief Delphi Invitational 4 10-26-2001 09:41 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
