Thoughts...King of the Hill
Hi Everyone,
I am curious, and not behalf on any one team, what people's analysis of the king of the hill strategy is. What does it gain you? Would you need to control the ramp the entire time? I'm curious what people think, if they have the time to comment on such a strategy. My own personal feelings it that it ties you to the ramp the entire match and severely limits offensive potnetial. -Justin |
I'd agree with your assesment overall. A Hing of the Hill doesn't necessarly have to sit there for the entire match... I certainly wouldn't suggest buidling a bully-bot incapable of dealing with scoring situations and adapting. That being said, it could thwart a lot of opponents if you can really stay there for the entire match. Don't expect a ton of QPs, and be prepared for some serious stress if you do it.
My personal favorite is the King of the Hill strategy. However, it does have some obvious flaws, such as the fact that your opponents are trapped on your side and your allies are trapped on your opponents side, assuming you lack a gate mechanism.
I believe that it can be made to work, but the question is, is the trade off worth it? That remains to be seen, probably until the matches. --Petey |
I agree with you, but I also believe that the 25 points will motivate many teams to try for it - some may take the entire 2 minutes to do it, while others will play the field and then do the mad dash at the end technique. In my humble opinion - the match es will be decided in the first 15 seconds and the last 15 seconds. But - what do i know I haven't witnessed a single match yet.
the king of the hill part will get interesting. the polycarbonate ground has zero friction, so sliding will happen. The only way to stay up is to keep moving. Wither that or use suction cups and afixiate your bot to the floor. I have an basic out line if you would like it about the suction cup idea. i want to know what strats you guys have for surviving the chaos!
There's more to it than friction...
(and I'm not talking about suction cups - they slide too easily) -Joel |
With large extensions, a robot could potentially block the whole ramp, not limited by the 36x30 starting size.
Also, although the traction on top will be bad, the traction on the ramp is bad as well, and may be worse, as there is much less surface area. |
#10
yes, bullying the ramp will be crucial, i mean, how do u win if u are not a "low rider"?
Bad |
#11
Suction Cups = bad
suction cups, if done properly, could almost garentee an immovable robot.
However, this stuff is very easy to scratch, and it WILL be scrateched and all it takes is one shallow scratch and your cups don't seal...muhahahahaha |
#12
Matt |
#13
uh oh i can smell the whole wheel width vs traction debate coming
#14
Re: Suction Cups = bad
Suction cups + *tiny* scratch on surface = no suction Suction cups + tiny scratch + vacuum = barely any suction Do as you will. ![]() - Katie |
#15
just F.Y.I.
The rules strictly state that there is NO use of any kind of vacume on the robot for any purpose. Also, you can't get a rubber that is too soft or otherwise it will get destroyed going up the mesh ramp. |
| Which Robot Do You Think should be King Of The Hill | mtaman02 | General Forum | 58 | 04-14-2003 11:35 AM |
| pic: 157 and 236 King of the Hill in the finals | CD47-Bot | Extra Discussion | 3 | 03-16-2003 12:03 PM |
| King Of The Hill And Others.... | Alex Cormier | General Forum | 18 | 03-12-2003 08:11 AM |
| King of the Hill | Rusted_Grail | Rules/Strategy | 7 | 01-07-2003 01:40 PM |
| DDR (?) on King of the Hill | Elgin Clock | Chit-Chat | 13 | 05-14-2002 01:52 PM |
