Go to Post Sleep is for the weak in week 6! - JesseK [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
GODUC
ADVERTISEMENT
Unread 01-08-2003, 10:36 PM
Neal Probert's Avatar
Neal Probert Neal Probert is offline
#1015 (Pi High Samurai)
Neal Probert is on a distinguished road
Send a message via ICQ to Neal Probert Send a message via AIM to Neal Probert Send a message via Yahoo to Neal Probert
Battery Voltage
At what value (bat_volt) does that battery get so low that it's not worth running the compressor, but keep the drive train alive?
Ypsilanti-Ann Arbor Area Robotics Club
YAAARC! The sound you make as your robot rolls off the workbench...
http://www.yaaarc.org/
Software Engineer (20+ years experience)
ProbeStar Technical Systems, LLC.
http://www.probestar.com/
Unread 01-08-2003, 11:28 PM
rbayer's Avatar Unsung FIRST Hero
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
rbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of light
Send a message via AIM to rbayer
Anything much below 10 Volts and you're going to have problems with everything on the robot. The controller will shut down around 8V.
New C-based RoboEmu2 (code simulator) available at: http://www.robbayer.com/software.php
Unread 01-09-2003, 07:45 AM
Unsung FIRST Hero
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Rookie Year: 1998
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
I actually believe that the Robot Controller resets at 7.5 V. However, please realize that the battery voltage depends on amount of load you put on it. As you put more load on the battery, the voltage of the battery decreases temporarily. This is perfectly normal. There will most likely be times during a match, when many of the robot components are running, that the voltage will drop below 10 V. It will probably also come back up to around 11.5 V. So make sure it's a sustained change before doing anything drastic.
Matt
Unread 01-09-2003, 09:18 AM
nwagers nwagers is offline
#0240 (Mach Vee)
nwagers is an unknown quantity at this point
Send a message via AIM to nwagers Send a message via Yahoo to nwagers
The constant in the code for battery voltage is only to set the threshold of the low battery light correct? Are there any inputs available for the battery voltage other than custom curcuitry?
Quick release battery connector and 120 amps n[ate]vw Electrical 6 01-18-2003 10:41 PM
Off-topic battery stuff. FotoPlasma Electrical 4 01-06-2003 11:19 AM
Output voltage in PBASIC diego25 Programming 7 01-31-2002 09:50 PM
connecting to the battery ahecht Technical Discussion 1 01-25-2002 04:15 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
