Go to Post using CD to answer my question is not the way to get the "ALL-BINDING FIRST ANSWER." - rees2001 [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
Authentic Touch Landscape
ADVERTISEMENT
Unread 01-14-2003, 04:52 PM
BBFIRSTCHICK's Avatar
BBFIRSTCHICK BBFIRSTCHICK is offline
Someone find me a FIRST team
AKA: Adriana
#1077 (was: All Stars)
Rookie Year: 2000
BBFIRSTCHICK is on a distinguished road
Send a message via AIM to BBFIRSTCHICK
Question Servo Specs
Dose anyone know where I can find the specs for the Servo's that were provided in the kit??
Team 59 "Ramtech": 2000-2002
Nationals 2001: Galileo Division Champions, National Semi-Finalist
Team 1077 "All Stars": 2002-????
Semi-Finalist, Peachtree Regional 2003 (507 and 356 Rock!)
Unread 01-17-2003, 10:18 AM
luckyguy9205 luckyguy9205 is offline
#0935 (ralierobotics)
luckyguy9205 is an unknown quantity at this point
Send a message via AIM to luckyguy9205
Thumbs up the specs
This is the Hitec HS-322 Deluxe Servo with the Hitec/JR/Z Connector.
FEATURES: Three pole motor.
One resin bushing.
INCLUDES: One Hitec Deluxe Servo with the Hitec/JR/Z Connector with, four 2mm x
15mm phillips head mounting screws, four rubber grommets, four
eyelets, one star shaped, one arm, and two arm straight servo horns
SPECS: Wire color codes: Black-Ground, Red-Power, Yellow-Signal
Operating speed: 0.19 sec @ 60 degrees at 4.8V
Torque: 39oz/in (2.8kg cm)
Weight: 1.51oz (43g)
Length: 1.57" (40mm)
Width: 0.78" (20mm)
Height: 1.43" (36.5mm)
Wire length: 12" (305mm) approximate
JXS 7/12/02
ir/kh
Andy harder
Q&A Discuss: Are specs available on the new motors/mounts? CD47-Bot Extra Discussion 3 01-15-2003 06:39 PM
motor specs? Gary Dillard Motors 0 01-04-2003 04:54 PM
bridge specs archiver 2001 2 06-23-2002 09:52 PM
On-board chip spec's archiver 2000 4 06-23-2002 08:55 PM
Motor specs kmcclary Chief Delphi Invitational 4 10-26-2001 09:41 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
