Go to Post Nonetheless, I would welcome it, as long as [The President] didn't restrict the number of discs that a Robot could hold. Oops, wait, too late, the GDC already did that. :-) - MooreteP [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Kettering University
ADVERTISEMENT
Unread 01-19-2003, 04:11 PM
viper viper is offline
viper is on a distinguished road
6 awg wire how much amps?
how much amps can the 6 AWG wire handle? we went on the belken site and got lost..
Unread 01-20-2003, 07:11 AM
Lloyd Burns Lloyd Burns is offline
FRC #1246 (Agincourt Robotics)
Rookie Year: 1997
Lloyd Burns is an unknown quantity at this point
Might we say adequate for the 120 A circuit breaker, given that breakers will handle overcurrent for a while before opening ?
Unread 01-20-2003, 12:38 PM
D.J. Fluck
Posts: n/a
According to the data tables on http://www.rbeelectronics.com 6 AWG wire should be able to handle up to a little over 200 Amps. In fact I know it can handle 200 Amps from personal expierence. Unless your team builds a machine that has high current draw, you should have no problems with 6 AWG wire
Unread 01-20-2003, 01:29 PM
Unsung FIRST Hero
Broadcast Eng/Lead Robot Inspector
AKA: Big Al
FRC #0111 (WildStang)
Rookie Year: 1996
viper,
The current rating on #6 wire is based on it's capabilities in free air and according to National Electrical Code it is capable of 105 Amps continuous for THHN type wire. Part of this spec is that the insulating jacket will not melt below 90 deg. C. However, this spec is based on continuous current over long period of time, not over the two minutes of match time we will encounter. What is more important to us is the resistance of the wire (length) used. A longer wire will drop more voltage at high currents so it is important to keep high current runs as short as possible. Don't forget that the total resistance is the sum of the positive wire, negative wire and all of the connection points. All things being equal, the 120 amp circuit breaker should adequately protect the #6 wire in our application.
Al
WB9UVJ
www.wildstang.org
________________________
Season Eighteen, what a spectacular year! It's has been a bumpy ride. All is better now, new parts are working fine. Champs were spectacular!
Telephone wiring Keiko173 Chit-Chat 4 06-17-2003 11:22 PM
Philosophy behind wiring rule C6... CBP at BAE Electrical 7 03-17-2003 05:05 PM
Drill Motor Connections archiver 2001 8 06-23-2002 11:49 PM
Shipped Wire Warren Boudreau Electrical 15 03-07-2002 08:00 PM
Motor wire sizes Tim Skloss Motors 5 02-13-2002 06:44 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
