Joystick questioin, FIRST response
This was posted to the FIRST fourm, and by their wording they are willing to allow you to modify joysticks that you provide?
Question: Rule C1 States that Joysticks may not be modified in any way, (cutting, drilling, rewiring) However we are allowed to make our own joysticks. This seems to me like the recent wheel rule in update 4(where you were allowed to make your own wheels, but you couldn't modify bought ones but the update did away with that rule) We can totally build our own joysticks, wire them ourselves, and yet we cant just add a switch to an existing one? This doesn't seem to make any sense to quite a few people. Why would we be trusted to manufacture a controller, but not to simply rewire an existing one such as adding a switch in an unused area of the base of the stick. I am asking was this rule actually thought through. Also if this rule is to stand why is the reasoning behind this? Answer: The intent of Rule C1 is to keep the uninformed from taking apart the components of the kit of parts, especially the control system components, and not being able to re-assemble them properly requiring FIRST to reissue replacement parts. Also, if the components of the control system are modified, the effect on the circuitry, especially the inputs, could cause damage to the IFI control system. IFI does not want to take this chance. We have tested the components of the control system and know that they will work. If you want to fabricate your own controls, you are taking on the responsibility of that system working and of it being compatible to the IFI system. If you have a problem, it is your problem to resolve. I hope this answers your question as to our thought process in requiring that the provided components not be tampered with or modified. Your question will not be posted on the forum. 36F |
| Fried program slots? | Jeff Waegelin | Programming | 18 | 03-19-2003 05:08 PM |
| question about one joystick drive programing | james700 | Programming | 13 | 01-29-2003 01:49 PM |
| robot goes haywire with the one joystick default code | Miles | Programming | 7 | 01-24-2003 01:58 PM |
| joystick problem | archiver | 2000 | 12 | 06-23-2002 10:08 PM |
| switching joystick axis????? | team222badbrad | Technical Discussion | 9 | 01-16-2002 10:07 PM |
