Double Solenoids - assembly.
We got our put together, but no matter what i tried they leak a trickle at 60 psi . . . which is not good but we can stand it.
But how do i wire it? Does it need two spikes? Or can i do it on one. I'm tempted to just use our single soloniod to run both cyliders . . .. please help. |
There is a diagram on page 11 of the robot on how to wire up some diodes to control the double acting solenoid with one spike relay
oooo, i was looking in the pneumatics manual.
Thank you. |
http://www.innovationfirst.com/FIRST...sersManual.pdf This shows you how to do it much easier. |
Last year, we used code to turn on the pump for one second every five seconds in order to keep our tanks charged up.
If your pneumatic system is leaking you need to check every connection, remember to use your teflon tape. Soapy water works great for checking for leak, at least for the ones you can't hear.
I think he means the leak occured in the solenoid that had to be assembled.
If I recall correctly, the valves were separate from the electronic bits, and two small screws and two rubber "mesh plates" were supplied in a little baggy. There were no assembly instructions anywhere, but our team just tried putting the mesh between the valve and the electronics portion of the solenoid. With both rubber pieces in, it leaked air at 10 PSI. We took one of them out (the one that doesn't have grooves to mesh) and left the other one in. We have yet to test this new set up yet. I'm also curious to know if there are any assembly instructions for those solenoids. |
The little leakage was with only the grooved rubber peice in.
But then I found a screwdriver that was small enough not to slip out of the little screws and fixed it. Heh, I don't know how to read electrical diagrams so I tried to do it without diodes (WHY ISN'T IT WORKING?! WHY!!!???) but then we figured it out. soons we get diodes our pneumatics will be complete. This whole 'build a robot' thing is just too much fun. |
#10
Yah, Adrianfixed his solenoid too
| FIRST Double Jeopardy! (8/27) | EddieMcD | Games/Trivia | 2 | 08-28-2003 08:41 PM |
| solenoids from last year | Antonio | Pneumatics | 6 | 01-29-2003 09:59 PM |
| Rookie Question. double solenoids... | archiver | 2001 | 2 | 06-23-2002 11:57 PM |
| Solenoids | archiver | 2001 | 9 | 06-23-2002 10:47 PM |
| Driving constraints in assembly | Jan Olligs | Inventor | 0 | 02-25-2002 06:11 AM |
