Go to Post FIRST has always been less than just a school activity for me and more of a way of everyday life. - Amanda Morrison [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Kettering University
ADVERTISEMENT
Unread 01-23-2003, 08:53 PM
Miles Miles is offline
Miles is an unknown quantity at this point
robot goes haywire with the one joystick default code
Greetings,
downloaded the single joystick control program from
first robotics site. Was able to download it to the robotic
without any problem. Now the question:
When we turn on the robot, it goes a bit crazy. It will
respond to the single joystick control movemets, but
once you release the joystick and it centers, the robot still
spins around. Have tried adjusting the wheels on the
joystick, but still doesn't behave properly. Is this a known
problem ? Ideas on how to have no movement when the
joystick is in the center position? Also ideas on tuning down
the sensitivity to joystick inputs.
thanks in advance.
Unread 01-23-2003, 09:07 PM
srawls's Avatar
srawls srawls is offline
Big O
#0122 (Nasa Knights)
srawls is an unknown quantity at this point
Send a message via AIM to srawls
Hmmm ... what I would do is keep the robot tethered up, and debug some values. Assuming you call your motor outputs driveL and driveR, put something like this in the bottom of your code:
Code:
debug ? p1_x
debug ? p1_y
debug ? driveR
debug ? driveL
debug "Filler Text"
debug cls
Then, run the robot and don't touch the joystick (keep it centered). Adjust the trim (the right and bottom wheels) until you see p1_x and p1_y are close to 127. Then Tape the trim down, so it doesn't move. If you move the joystick, then it goes to center, and the p1_x/p1_y don't say 127, then you've got a problem with your joystick. If p1_x/p1_y do say 127, but driveR/driveL don't, then there is a problem with your code (unlikely since it is the default code). If they all say 127 but the wheels are still moving, then you've got a real problem! (in that case, check the wiring to make sure it's all correct, and the pwm cables go to the right number that the serout command expects).
Sorry I can't be of more help, but I haven't had this problem before, so I don't know what to say.
Stephen
PS. Kind of obvious, but just in case: when you do this testing, make sure you set your robot up on some blocks so the wheels can move freely without contacting the ground.
Unread 01-23-2003, 09:08 PM
Harrison's Avatar
Harrison Harrison is offline
None #0783 (Mobotics)
Harrison has a little shameless behaviour in the past
That sounds like either the centre points are messed up in the program itself, or your joystick is not centred physically.
If neither of those are true, maybe there is something actually wrong with the joystick? Try swapping it with the other one maybe?
Also, are you sure you have all the motors/victors wierd properly to the robot controller?
Harrison Ruess
2002/2003 Team 783 Captain
UOIT '08 Alum
Unread 01-23-2003, 09:11 PM
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
I had this exact prob on the Edu-Robot. I have yet to test out the Full size sys.
1139 Alumni
Unread 01-23-2003, 10:29 PM
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Ian W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to all
Send a message via AIM to Ian W.
make sure the PWM outputs are correct. i did this, and well, when the robot flipped out and almost broke a few legs, i went through and realized all the stuff i forgot to change .
AIM --> Woloi
Email --> ian@woloschin.com
Unread 01-23-2003, 10:36 PM
Mark Hamilton's Avatar
Mark Hamilton Mark Hamilton is offline
Belphegor made me do it.
#0108 (SigmaC@t)
Mark Hamilton will become famous soon enough
Send a message via ICQ to Mark Hamilton Send a message via AIM to Mark Hamilton
Use the dial on the joysticks to adjust the calibration. Make sure your PWM's are correct. You might want to put the robot up on blocks before you do this.
Retired member of Team 108
Unread 01-23-2003, 10:49 PM
srjjs's Avatar
srjjs srjjs is offline
Slightly Rehabilitated
AKA: Larry Wang
#0840 (Aragon Robotics Team)
srjjs will become famous soon enough
Send a message via AIM to srjjs
Maybe this is not a programming issue at all and you just have a low battery. When the battery is low, the controller doesn't get enough energy and weird things start happening.
SVR Imagery Award
SVR Semifinalists with 473 and 687
RIP Andrew Dang
3/22/2004
Unread 01-24-2003, 01:58 PM
JLambert's Avatar
JLambert JLambert is offline
#0151 (Wild Cards)
JLambert is an unknown quantity at this point
Send a message via ICQ to JLambert Send a message via AIM to JLambert Send a message via Yahoo to JLambert
To help with the joystick sensitivity, you could add some code to create a "dead-zone".
Essentially, the robot would think the joystick is in the neutral position unless it is moved in a direction a certain amount.
Code:
'---------- Joystick Dead Zone -------------------------------------------------------------------------------
if ((p1_y > 137) OR (p1_y < 117)) then end_p1_y_dead_zone_adj
p1_y = 127
end_p1_y_dead_zone_adj:
if ((p1_x > 137) OR (p1_x < 117)) then end_p1_x_dead_zone_adj
p1_x = 127
end_p1_x_dead_zone_adj:
Try adding that before the part that says 1 Joystick Drive. It may help a bit.
Justin Lambert
02-03: Programmer Team #151
How much planning goes into your robot? Jnadke General Forum 41 01-29-2006 08:29 PM
Default Robot Code lvhsrobotics Programming 2 01-10-2003 03:55 PM
WASH Palm scouting at the Championship Mike Soukup Scouting 2 04-19-2002 02:14 PM
Rookie Programmer has question about the default code DanL Programming 3 01-26-2002 06:59 PM
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 11-26-2001 08:39 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
