Solution to Timing Loops
I have found out how to time. Based of the information from Innovation First, a loop is every 26.2 ms, assuming your code does't lengthen it. Based off of that, there are 38.167938931297709923664122137405 loops per sec. So to do close timing without overloading the stamp, you do:
Time VAR byte RealTime VAR byte Time = Time + delta_t + 1 if Time > 38 then Time = Time - 38 RealTime = RealTime + 1 EndIf This way only uses 2 bytes insted of a byte and a word. I tryed the delta_t * 262 / 10 but it overloaded the stamp and was very inaccurate. Based of of this formula, then the basic stamp will be 0.530431579 seconds fast at end of match. You can check this information on this xls I inclosed. |
i must applaud you for your idea. I myself, being a rookie programmer on a rookie team, am just getting the hang of the language, but after reading the forum got this idea yesterday, but then flushed it out, on one basis. doesn't delta_t count the total number of packets missed since starting the program? ![]() -Anthony |
Re: Dear god thats great
thats good to hear, you always want to check your bases. you know, play it safe.
-Anthony |
Did you get the xls. If you guys didn't, then can I have a email address if you want a copy or to post it in the internet
You can attach it to your post as a file. That would probably be best. That way everyone can download it straight from here.
Re: Solution to Timing Loops
It's really not that hard to just figure out the numbers by guess and check. You can do a timer with 2 bytes too, only difference is that you can only count to 255, and when you reach this number you simply start a new step, as documented in my programming sample in the white papers. Last edited by Greg McCoy : 01-27-2003 at 07:12 AM. |
If you do the research like I did, then you would see that a loop is 26.2 ms a loop. If your code is shorter then you wait at serin until you get the information and start the loop over. If you take too long in your code, then the delta_t comes in. It count the number of loops you missed as long as it is in the serin. If you miss 5 serins then you have the basic run error. So in theory, this should be accurate.
all i know is this code works. I played with basic autonomous mode today (this isn't that sad, seeing as i am the only real programmer at my school, this is a rookie team, and i have taught myself almost all of the code) and this works like a charm. Since most people only use timing in auton mode, you will only be off by about .066 seconds, and that is extremely insignificant. (It was so little that i didn't notice at all)
-Anthony |
#10
one question. why the timing loops? why not just a counter?
i made a little program a few days ago, all it does is use a byte and a nibble, and based on the counter and nibble advances through a select case. all you do to control it is adjust the byte to how high to count, and always advance the nibble by one. you can get up to 18 operations in this way, actually more if you don't use the full 255 loops from one byte at a time. if this doesn't make sense, i'll post the code tomorrow afternoon when i find it. it's very simple when you see it, and it works fine. no need to worry about time, because if the loop gets longer, even a timer would get screwed up. |
#11
Yeah, that's pretty much what I did. It seems to me that it does the exact same thing with less complexity and the exact same efficiency if done correctly.
#12
First, this thread starter knows what he's talking about. Second, a counter counts loops. The number of loops you get in one second changes. Don't believe me:
copy a simple statement 100 times, or use some calc in your program and see how slow the counter goes. I can forsee that this years coding is that complex when compared to last years (all we needed were a few if statements). The delta_t is the only TRUE thing in your code, so it is imperative that you do the auton mode the way suggested, and do NOT use counters. GUESS AND CHECK IS NOT HELPING US LEARN ANYTHING |
#13
uh, i can control how long it does something based on counting with cycles AND delta_t. it's the same as a timing loop, minus the extra memory and added difficulty. and i've seen no problems so far with my code. sure, it aint pretty, but it's dead reckoning, it's not supposed to be!
#14
There is no advantage to converting Stamp loops to "real" time. It is a 1-to-1 conversion, meaning that each "real" time value corresponds to some fixed number of loops and vice-versa. For example, the following code would do exactly the same thing:
Code:
loopCnt VAR byte loopCntHigh VAR nib loopCnt=0 loopCntHigh=0 SERIN... if (loopCnt + 1 + delta_t > 255) then loopCntHigh=loopCntHigh + 1 : loopCnt=loopCnt+1+delta_t-255 else loopCnt=loopCnt+1+delta_t SELECT (loopCntHigh<<8 + loopCnt) CASE range1Low TO range2High 'do stuff CASE range2Low TO range2High 'do other stuff CASE ELSE 'do even more stuff ENDSELECT SEROUT... Questions about the above stuff? Email or PM me and I'd be more than happy to explain. |
#15
Once again you correct me!!! Oh, I'm lazy anyway but thanks for the free code. Only one question have I:
where'd you get the 8 from in SELECT(loopCntHigh<<8 + loopcnt) i think you and i are on the same page (only i'm on a different plane) , and its great learning from you!!! |
| Timing of nats for next year | Ian W. | Championship Event | 13 | 03-03-2003 05:28 PM |
| Way back there. Size of Nationals, and a solution | archiver | 2001 | 23 | 06-24-2002 02:28 AM |
| what is or isn't a timing belt? | archiver | 2001 | 6 | 06-23-2002 10:26 PM |
| two sided timing belt | archiver | 2001 | 3 | 06-23-2002 09:34 PM |
| Dual Sided Timing Belts | Lachuck894 | Technical Discussion | 9 | 01-14-2002 09:10 AM |
