Go to Post I will gladly be pied if that's something you guys want. I know I have people from the Clarkson FIRST dorm floor who will shell out PLENTY of cash for the chance to pie me in the face! - Libby K [more]
Unread 02-02-2003, 06:54 PM
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
Negative Bus
Hello everyone
We are still working hard on the robot, and decided to make our wiring neater by having a "negative bus bar" that goes across the area that holds our electrical components. It is just a piece of angle iron that all our negatives from relays and speed controllers connect to. The negatives from motors, etc. are connected to relays/pwms. The bar is connected straight to the battery negative terminal.
Are we allowed to design our wiring like this, or do we have to use the negative plate on the circuit breaker panels? We still have not finalized the drive system, and rewiring everything would just mean even more work to be done this week.
Unread 02-02-2003, 08:09 PM
rbayer's Avatar Unsung FIRST Hero
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
rbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of light
Send a message via AIM to rbayer
Section 3.2.1 of the Robot Manual:
All electric current used on the robot must be conducted via wires or electrical paths through
electrical components. No part of the robot, such as the chassis or superstructure shall be
used for this purpose. All Common (-) circuits must be returned to the negative terminals of
the power distribution circuit breaker panels via appropriately sized wire.
Unfortunately, I think you're not going to be able to do this.
--Rob
New C-based RoboEmu2 (code simulator) available at: http://www.robbayer.com/software.php
Unread 02-03-2003, 12:20 AM
Lloyd Burns Lloyd Burns is offline
FRC #1246 (Agincourt Robotics)
Rookie Year: 1997
Lloyd Burns is an unknown quantity at this point
Check those rules again...
Except as noted herein, each Ground (GND) wire from a Speed controller, relay, or Robot Controller (begin underline) must go directly (end underline) from that item to one of the 12 Common (-) terminals on the circuit breaker Fuse Blocks.
They make the exception that certain low power items may be returned together.
NOTE: with one 12 fuse block and a MAXI fuse block, 16 circuits in all, you only get 12 returns. Some crowded, eh ?
Unread 02-03-2003, 06:33 AM
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
3.2 Wiring the Robot Controls
3.2.1 Power Distribution Circuits
I think that says it all. However, if the buss was insulated from the chassis and was itself somehow insulated, that is common electrical practice. It is just not allowed on the robot. Sorry.
Al
WB9UVJ
www.wildstang.org
________________________
What to do on a 30h bus ride to houston MichalSkiba Chit-Chat 19 04-09-2003 10:43 AM
What do you do for fun on the bus rides? FatHead547 Chit-Chat 1 03-12-2003 09:17 PM
Will There Ever Be Negative Scores? Joe Matt General Forum 30 01-18-2003 04:15 PM
Share a bus. Useless member Regional Competitions 0 01-13-2003 09:59 PM
Stop Posting About Negative Scores Adam Y. General Forum 25 01-13-2003 02:44 PM
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
