Is it legal for the human player to flip a switch for the movement of the robot (during the autonomous time) when they place the robot down on the field? The switch is changed on placement of the field, and the input of the switch is read during the auto period.
It's absolutely legal. Most teams will have a similar setup, to either tell the robot which side of the field its on, or to switch between programs.
In fact, Woody even suggested this at kickoff.
Totaly legal. We have a small one now we are using durring testing.
thakns
I was just freakin out today during a programming binge with the other programmer on the team. Thanks
Is this switch for the Human Player to throw or the drivers moving the robot on to the field. Remember 10sec is not long to move boxes and flip a switch. People who have tried on my team have had problems just getting the boxes out in the 10 sec. So I would proably just have the drivers do it.
Silly me. Mabey I should be more careful while reading the posts.
its ok
Hey, at least I got some use practicing quoting...
#10
Re: its ok
cool switch
Digi-key part number CKN5029-ND, $10.38. This is a one-digit thumbwheel switch with BCD output. It has a small mechanical digit that increments/decrements by pressing one of two little buttons on it. The output is 4 bits representing 0-9, so you get 10 possible combinations. You can get 8 combinations (0-7) using only three of the outputs if you're tight on space.
#12
I was joking... Last edited by KZos550 : 02-04-2003 at 06:22 PM. |
| A better autonomous method.. | randomperson | Programming | 4 | 02-24-2004 05:02 PM |
| variable? | manodrum | Programming | 11 | 04-01-2003 04:20 PM |
| autonomous mode problem on field | Chris_C | Programming | 17 | 03-26-2003 06:11 PM |
| Autonomous Kill Switch | UCGL_Guy | Programming | 8 | 01-15-2003 04:39 PM |
| Need help with 255 Variable | Joseph F | Programming | 18 | 02-26-2002 01:49 PM |
