Go to Post By the way, a piece of advice to all those who haven't gone to Manchester for Kickoff before: Go. It's something you have to do at least once in your time in FIRST. - Billfred [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Kettering University
ADVERTISEMENT
Unread 02-03-2003, 05:40 PM
adambarnett adambarnett is offline
adambarnett is an unknown quantity at this point
Team 364 Near Completion(With Pics!)
Our Robot is very near completion. The highlights are a fully functional two speed transmission, allowing us to switch gears on the fly from 9.8 ft per second high gear, to a 5 ft per second low gear for pushing. We also have four suction cups positioned on the bottom of our robot to allow us to stick to the HDPE and a box bashing arm. We plan to be 14 inches tall to allow us to fit under the bar. Here's a pic(minus the suction cups, I'll post an updated picture later). Check our our website for more information and pictures.
Unread 02-03-2003, 06:12 PM
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Reject False Icons
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Nice. I really like the tires.
Just wondering, is your favorite game on your team Metroid FUSION!?!?!?
Get a Shirt
Unread 02-03-2003, 07:14 PM
I don't get it?...
Unread 02-03-2003, 09:54 PM
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
A quick note about those tires... We used the same ones last year. We noticed that on the carpet, they don't have a whole lot of traction. (Well...they do...but you can get more) Wear them down a little so you have more surface area and make perpendicular grooves in them (so you have some nice 90-degree angles). To make the grooves, we duct-taped three hacksaw blades together and sawed down each grove. We had a noticeable amount of gained traction. Just a thought (Grooves will also help a lot on the mesh, too)
Maybe you already had plans to modify the tires...or not. But this goes to any team that has never used these wheels before or would just like to get a little more out of them (We ditched these wheels for the wider ones )
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 02-03-2003, 10:04 PM
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Rookie Year: 2000
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
We used those tires last year too, we cut grooves like evulish said and they grooves worked great,
to lose some weight you can mill out the part of the wheel in between the outside and the hub, be sure to go around the bolt holes, just pull the two pieces apart off of the rubber and you can cut it with a jigsaw. It will cut out about 25% of the weight.
Unread 02-04-2003, 07:23 AM
Yea we did something similar to the wheels last year. We actually ended up attaching breckoflex to them, it worked pretty well.
Unread 02-04-2003, 09:41 PM
Wink
We now have some videos up if you guys want to check them out
Unread 02-04-2003, 09:45 PM
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
#0470 (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
*krrrschhh* *plop plop plop.. plop* very nice attachment mechanism
Ompha1oskepsis 118448018 bjoerges@gmail.com
Unread 02-04-2003, 10:01 PM
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
Rookie Year: 2000
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
Suction cups= awesome
in the video it looks like all four wheels are lifted off the ground- does this actually happen? I seem to remember a rule that says you can't do that.. hmm- looks in rule manual
Unread 02-04-2003, 10:08 PM
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
very cool. Looking at your light, unless it raises itself, it is only visible from one side, the top. Unless im just an idiot and going blind.
Cory
*2001-2004: Team 100
2005:
*Sacramento-Inspector/Referee
*UTC-Field Reset
*SVR-Inspector/Referee
*Nationals-Inspector/Referee
2006-???: Mentor, Team 254
Unread 02-04-2003, 10:20 PM
MikeDubreuil's Avatar
MikeDubreuil MikeDubreuil is offline
Carpe diem
FRC #0125 (Nu-Trons)
Rookie Year: 1999
MikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond repute
Send a message via AIM to MikeDubreuil
Definatley a very cool robot. If you take a look at all the videos the light seems to be retracted into the body in all but the suction video. Since they only need the light down while getting under the bar, I'm sure the reason they kept it retracted is because of how annoying it is ;o)
Unread 02-05-2003, 07:29 AM
yea the light goes up and down so we can get under the bar. The suction cups lift the whole robot off the ground... I don't think it's against the rules?
thanks for all the comments!
Unread 02-05-2003, 08:09 AM
I looked through the rules and I couldn't find it. That rule wouldn't make much sense either...lifting your robot up is no big deal, and plenty of teams are going to have suction cups....
Here's another picture:
Unread 02-12-2003, 11:20 AM
Tyler Olds Tyler Olds is offline
FIRST Lifer
FRC #2826 (Wave Robotics)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
Send a message via AIM to Tyler Olds Send a message via Yahoo to Tyler Olds
We were going to use suction cups.............. but we found a major problem...........
If there are scratches in the surface of the ramp, they don't work. I would make sure that yours works just in case.
Team 2826 Wave Robotics Mentor Team 93 NEW Apple Corps Alumni
Emcee at the following events in 2013: Northern Lights, Wisconsin, 10000 Lakes, Championships, and helping at IRI.
Wave Robotics 2013 Season:
Northern Lights: Chairman's Award and Regional Finalists (Thanks 269, 1259)
Wisconsin Regional: Regional Finalists and Quality Award (Thanks 2481, 269)
Championships: Newton Quarter-finalists (Thanks 341, 68)
Checkout the Insight LT at http://www.bitbuilttech.com/
The Death of FIRST Anton Abaya General Forum 23 05-03-2006 04:18 PM
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 03-31-2003 06:34 PM
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 02-27-2003 11:18 PM
More 'Best' Robots (a well thought list) archiver 2000 2 06-23-2002 10:11 PM
Disqualifications archiver 1999 13 06-23-2002 08:53 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
