Go to Post the golden rule of robotics for the 21st century: Do unto robots as you would have them do unto you - KenWittlief [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Dr. Chang D.D.S.
ADVERTISEMENT
Unread 02-06-2003, 09:06 PM
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Team Role: Leadership
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
Question PBasic 2.5 vs. 2.0
I am a rookie programmer and so far have taught myself all of the code for PBasic 2.0. Looking at the codes posted, I have noticed that 2.5 is much simpler and If/Then(and, in 2.5, else) statements are MUCH easier. I have 2 questions. First, is there any advantage to PBasic 2.0 over 2.5? Secondly, do you need a certain onboard processor to support PBasic 2.5 or do all of them support 2.5 and 2.0?
Thanx,
Anthony
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
Unread 02-06-2003, 09:08 PM
rbayer's Avatar Unsung FIRST Hero
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
rbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of light
Send a message via AIM to rbayer
The only thing you need is the new editor, available from InnovationFirst.
New C-based RoboEmu2 (code simulator) available at: http://www.robbayer.com/software.php
Unread 02-06-2003, 09:09 PM
Jeff_Rice's Avatar
Jeff_Rice Jeff_Rice is offline
ElementisRegamusProelium
#1359
Jeff_Rice will become famous soon enoughJeff_Rice will become famous soon enough
2.5 is a very early version. It is possible there are compiler bugs. Compiler bugs + experimental coding are often bad. Is it the code, your logic, or the compiler that is bad?
"He said my name is Private Andrew Malone
If you're reading this then I didn't make it home
But for every dream that's shattered another one comes true
This car was once a dream of mine now it belongs to you
And though you may take her and make her your own
You'll always be riding with Private Malone" David Ball, "Private Malone"
Unread 02-06-2003, 09:13 PM
AKA: SonKenshin
I'm not having any problems, and i have the compiler, but i was just wonderingn if ther are any advantages to 2.0 over 2.5 (besides already knowing 2.0 fairly well and not wanting to learn a new language halfway through the building session)?
-Kesich
Unread 02-07-2003, 02:08 AM
JoshB JoshB is offline
JoshB is an unknown quantity at this point
There isn't a real advance or disadvance to either 2.0 or 2.5. The difference is with the programmer, which are you more comfortable with? You technically can do the same things with each, IMHO 2.5 is easier to do most things.
To the processer is makes no difference, both 2.0 and 2.5 are tokenized into the same machine code for the processer to understand. As stated above you need the newest editor to be able to Tokenize 2.5.
Other than that, you make the call as to which will do what you want it to.
Help this helps!
Unread 02-07-2003, 09:38 AM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Jeff Rice's post is why my team decided to stick with the 2.0 syntax and old compiler. That is pretty much the only advantage, though.
Unread 02-09-2003, 09:06 PM
AKA: SonKenshin
Smile thanx
Thanx for the help. I think next year i may convert to 2.5, but seeing as i already know 2.0 and there is no advantage to 2.5 (that and they are still working out some of the bugs).
Thanx again.
-Kesich
Broken PBASIC 2.5 Complier? Mike Yan Programming 12 02-01-2003 08:11 AM
New Stamp Editor & PBASIC 2.5 Jnadke Programming 8 01-24-2003 06:57 AM
RoboEmu 1.09 (supports PBASIC 2.5) rbayer Programming 22 01-21-2003 04:22 PM
PBASIC 2.5 Questions Noah Programming 6 01-10-2003 06:26 PM
PBASIC 2.5 answer from Parallax JasonS Programming 6 01-07-2003 06:21 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
