Go to Post Pretty robots, who cares? Quality robots are another matter. - Steve W [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Kettering University
ADVERTISEMENT
Unread 01-15-2002, 03:13 PM
Brian_Lim's Avatar
Brian_Lim Brian_Lim is offline
#0907 (EY Cybernetics)
Brian_Lim is an unknown quantity at this point
Send a message via ICQ to Brian_Lim Send a message via Yahoo to Brian_Lim
1/4" Aluminum Plate
In the additional parts list, the thickness states up to 1/4". Is it possible to bolt two aluminum plates together to create a 1/2" thick piece? Is it also possible to cast, with 1/2" aluminum, thicker pieces?
Brian
Unread 01-15-2002, 03:26 PM
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Rookie Year: 2000
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Yes, you can bolt two pieces of 1/4" aluminum together to get a piece 1/2" wide. You can also weld the two pieces together.
Also, you can cast aluminum as long as you don't change the property of it. This means you can't add anything else to the mix.
Hope this helps.
Wayne Doenges
We Build Robot and Careers
2012 BMR #7th seed, Winners Thanks to FRC Team 1756 and FRC Team 4028, UL Safety Award and GM Industrial Design Award
2010 BMR #1 Seed, UL Safety Award (Threepeat), Engineering Excellence Award, Quarter finals. CT Regional, Entrepreneur Award, Finalists
2009 Boilermaker, Quarter Finals, Imagery and Safety. (second time) Awards. IRI, Outstanding Quality. CAGE, Best feature and winners
Unread 01-15-2002, 04:35 PM
Brian_Lim's Avatar
1/4" Aluminum Plate
Aluminum is an alloy... so what is the definition of aluminum? Aren't there many kinds of aluminum? Can we melt down any kind of aluminum? What is considered aluminum, aircraft aluminum or junk heap aluminum? What does that mean we can't change the chemical composition, if there are many kinds of aluminum?
Brian
Unread 01-15-2002, 05:32 PM
AKA: Warthog
Rookie Year: 2000
Refer to page A-7, rule # K6.
I quote "The melting and recasting of materials, such as a block of aluminum, is allowed as long as the basic alloy or chemical composition is not changed" end quote.
Wayne Doenges
Gearbox Lord Nerdlinger Motors 20 07-14-2003 11:38 PM
Bosch Aluminum Structural Framing Carl Owenby Technical Discussion 37 01-15-2003 08:11 PM
license plate archiver 2000 4 06-23-2002 11:32 PM
Difference in aluminum archiver 2001 1 06-23-2002 10:49 PM
Let's get some aluminum extrusions archiver 1999 3 06-23-2002 10:12 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
