Go to Post "Greatness isn't achieved by doing the uncommon things but instead by doing the common things uncommonly well." - Wayne C. [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Genisys
ADVERTISEMENT
Unread 03-01-2003, 04:47 PM
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
Q&A Discuss: Optical sensors with EduBot
Thread created automatically to discuss a question in the Q&A Forum.
Is there any good way to power a banner sensor/optical sensor with the EduBot? We could connect it in the same way that we would for the RC, but we are worried about whether the ground pin on the EDU-Rc could accept the 7.2 volts from the battery, instead of the 5 volts sent by the signal pin. The banner sensors work on 7.2 volts, but they do not work on 5 (6.6 is about the limit).
Unread 03-01-2003, 04:58 PM
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
Optical Sensors -> Edu-Bot
I found out how, without an external power source. Apparently the optical sensors run fine on 7.6 volts.
I did the following:
I attached the brown wires (+) to the positive wire of the Edu-RC on a parallel circuit. I then attached the white wire wires to the digital input pins on the board, and connected the blue wires to the digital ground pins on the board, and it works perfectly.
The only issue is that the optical sensors turn on before the robot does - when you plug the battery into the board, the circuit is completes and the optical sensors turn on, so you better not leave the battery plugged in. Oh, and the optical sensors tend to eat up the Edu-Bots batteries in about 15-20 minutes, if left constantly on.
Cool, huh? None of that external battery stuff
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
Unread 03-01-2003, 05:37 PM
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Re: Optical Sensors -> Edu-Bot
The GND on the EduRobot is no different than the (-) on the battery. You're better off connecting the blue wire directly to the battery just in case the traces aren't able to handle the current.
While it makes sense that the sensor will be able to operate on less than 10V, it definately will not operate on anything less than 5V. Don't be surprised if the sensors behave erratically when the voltage fluctuates.
The best moments of our lives fall in two categories: those that did happen and those that did not.
optical sensors majormusic2005 Electrical 5 03-11-2003 08:32 PM
Optical sensors with EduBot Gui Cavalcanti Robotics Education and Curriculum 5 03-02-2003 09:05 AM
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 02-15-2003 09:58 PM
optical sensors acting strangely rosebud Electrical 10 02-02-2003 11:29 PM
EDUbot Sensors marlon_jbt Robotics Education and Curriculum 11 12-19-2002 12:38 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
