hooking up sensors to controller?
This may have already been asked before but how I supposed to hook up the sensors so the robot can receive data from them? I thought all we had to do was solder the wires to an adapter and hook it up to the RC. One of the engineers was talking about hooking it up to a ciruit and something about and amplifer. Even if I was wrong, isn't what he is suggesting more then needed?
I believe the sensors that come in the kit are described in the specification. Their connection to the A/D port is also described in one of the section. On the other hand, if you are talking about other sensors....say, something contained in the CUSTOM CIRCUIT, then you can do alot with amplifiers and such. That is what the word CUSTOM refers to. Please explain in a little more detain and I'm sure I will understand. Thanks, -Quentin |
Re: Re: hooking up sensors to controller?
(sloppy fingers get me every time!) ![]() |
I am talking about the ones that came in the kit. I am trying to do this blind, I'm not sure where the specifications are. We may still have them or they may be lost.
Find the FIRST manual, and towards the end, it will tell you how to hook up each sensor (i.e. which wire goes to which pin). Then head over to innovationfirst.com/FIRSTRobotics/ and download the Control Systems Manual. There it will tell you the PBASIC variables that you have to use to get values from the sensor.
Diego |
Here's what you'll need.
1) Section 2.0 of the robot.pdf file. It was erroneously omitted on the initial release, but they have since posted it. Section 2 outlines all of the eletrical requirements for your robot. 2) A copy of the InnovationFIRST Control manual. You can download that from the IFI website. Contained in the document are tables defining the pin definitions for the analog and digital data ports on the robot controller. Analog inputs included in the kit are potentiometers and the yaw rate sensor. Be careful with the pots, you wire them differently on the robot than you do on the operator interface. Digital inputs are limits switches, pressure switches, and optical sensors. That should be enough to get you going. Remember to read all of the docs carefully before you power up the first time and make sure you have somebody ready to turn off the circuit breaker. Good luck, I hope it helped. |
| C controller | Rorschach | Kit & Additional Hardware | 1 | 10-29-2003 06:21 PM |
| Robotics Tournament at Sensors Expo & Conference | Kyle Fenton | Off-Season Events | 4 | 05-04-2003 11:15 AM |
| serious problem found - robot controller resets when jarred! | KenWittlief | Electrical | 23 | 03-19-2003 12:30 PM |
| Hooking up Controller to computer for programming. | Dragon45 | General Forum | 3 | 01-29-2003 11:22 PM |
| pre-built autonomous sensors? | BandChick | Technical Discussion | 4 | 01-05-2003 09:06 PM |
