Go to Post Most members of the CD community are happy to help one another. But searching before you post is standard forum etiquette... - KathieK [more]
Go Back   Chief Delphi > Competition > Championship Event
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ProCare Services
ADVERTISEMENT
Unread 04-04-2003, 05:39 PM
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Rookie Year: 1999
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
How to pass your inspection at Nationals, the EASY way
So your team is going to nationals, and you want to pass the inspection, coming from an tech inspector here is what you should know from us.
Obviously make sure your robots is 130 lbs or less and fits in the box.
While it should also be obvious, don't use 883 speed controller. At this same time check to make sure the Van Door isn't driven by a spike. Interestingly enough I saw for the first time a blue 884.
Have your number on 4 sides
For fuses, only the CIM and Drill can have 40A breakers, don't use them on the others even if you were tripping the 30's you can't use the 40's on other motors.
Pneumatics - Don't wire your pressure switch in series with the pump even if it works.
Look at your valves, you should have 2 small double solenoids and a single larger festo single solenoid. That's it!
Above all, don't say to the inspector, "We were in two regionals already and they never caught it!" So far nearly every team has said the same thing and that doesn't magically make it legal that another previous inspector missed the error. It actually is kind of annoying to think that there is something on your robot that is outside of the rules and it should be allowed since no one noticed it before.
Double check the check off sheet the inspector will use and your life (And the inspectors) will be nicer.
Good Luck
Chamionship Qualification - feedback needed ASAP! dlavery General Forum 97 10-11-2003 06:17 AM
What happens if your robot doesn't pass inspection? Tton General Forum 10 01-08-2003 08:50 PM
Please help make the Nationals in Houston AWESOME ... You be the Tournament Director Natchez General Forum 42 12-13-2002 05:50 PM
Meeting at Nationals Gui Cavalcanti Programming 43 05-05-2002 11:45 AM
Making heads or tails of the new announcement... Jessica Boucher General Forum 66 09-26-2001 10:13 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
